Accident or sabotage?
bw77
Upstate NY
Accident or sabotage? - SOLVED
It's a vent hole, see my last post in this thread.
2 days ago I took my car to the auto repair dept of a very large department store chain for an alignment. They did the job and I drove home. Next day I started work on replacing a front wheel bearing and noticed a pin-size hole in the rubber boot on the inner cv joint. Based on the small amount of grease on the control arm below, this hole just happened.
I removed the half-axle and patched the hole with a rubber bicycle tube patch and got it all back together and did a short drive and it is holding. I also ordered a boot repair kit.
Not sure what to do further about it, since I have no way to prove anything.
Was this an accident and they didn't want to tell me? Or sabotage because someone doesn't like people who drive old Volvos? Or something else?
The boot is in very good condition. No way this hole just happened.
Don't know what to think.
Virgil Cain
Never attribute to conspiracy that which can be adequately explained by stupidity.
dmeadow
Houston, Texas
Well said. To believe it was done on purpose, you'd have to think someone in that shop assumes:
1) That it will take a fairly short time for that CV joint to fail because of the hole,
2) That you'll bring it back to that chain store to be repaired, and
3) That whoever did the damage will still be working at that chain store.
I doubt the guy at the chain shop is going to believe all those things to be true enough to sabotage a CV joint.
MattT
Probably accidental. "Large department stores" ain't exactly famous for hiring good techs. Plus nobody in their right mind would deliberately create extra work on a volvo:lol_hitti
Also why did you get an alignment the day before replacing a wheel bearing:headscrat
bw77
Upstate NY
I have had a problem with short wheel bearing life, so I wanted a mechanic to check the suspension. They told me the suspension was good, but it needed an alignment according to the printout. So I had them do the alignment. Then I replaced the wheel bearing the next day. It doesn't affect the alignment. I realize it seems like the wrong order to do things.
red
Hudson Valley, NY
Guess accidental but definitely talk to the manager about it. Just to keep it from happening again to someone else. Or so they notice a pattern.
Personally learn the hard way never get your car inspected at a garage that isn't busy (ie. bays full and cars in the lot waiting to be serviced). Cause when they do the inspection they're looking for work. They have overhead to paid for and you're the lucky one helping out!
nehog
Jaffrey, NH
One must also consider the possibility that it is unrelated! It well could have been a bit of road debris picked up and that holed the boot. It happens.
rockchucker
Seattle WA
If the Wheel Bearing had ANY play at all then it will affect your Alignment. Even just replacing the Wheel Bearing with a new unit will affect the Alignment settings.
***** to hear that you may have been sabotaged. I definitely would not take my car to those guys anymore. CV Boots don't usually just sprout a pinhole with perfect roundness. Usually the Rubber degrades and cracks allowing contaminants into the mix. Pliable Rubber doesn't just have pinholes magically appear.
Thruxton
Virginia
Not exactly enough evidence to make a case, IMHO. If you were able to say,"the day before I had been replacing the front wheel bearing and did not notice a hole," that would be one thing. This is just minor paranoia. Again, IMHO. Fix your car, get on with life.
jhelrey
MN
Maybe it is a hole the manufacture had to fill it with grease. There could have been a plastic or rubber plug in it. Look at your other one...
Benji
Taxis River N.B Canada
Hard to try and blame the shop for it if they did it or not because you never seen it the day before and you never know something off the road may have hit it strange things happen...... If it was a perfectly round hole though I would wonder.
jw1968
Evansville,IN
I wonder if it is a "relief hole" to keep some fellow from pumping it so full of grease that it bursts. Some folks don't know it's full until it's running out somewhere. Check the other side.
treasureseeker
Why does the boot look swelled up along the ridge area like it is overfilled with grease or came in contact with something that swelled the rubber.
SMKS
USA, planet Earth
To the OP-
How long has it been since you were under the car and looked at the boot?
It could have been that way for a while.
ForceFed70
BC, Canada
If it was sabatoge I would have expected the shop to say "Oh! And by the way, we noticed that this boot has a hole in it. Would you like us to repair it as well?"
bw77
Upstate NY
I will look at the other side. If it does turn out to be a vent hole, I will most definitely feel like a vent hole.
bw77
Upstate NY
I checked the pass side, and sure enough, there is a vent hole there. Not leaking, but looks like it seeped a little at one time.
I must have opened it up when I was moving around the driver side axle.
Thanks to jhelrey and jw1968 for pointing this out.
My sincere appologies to unnamed large department and auto repair chain.
Live and learn.
