It has been mentioned before in this thread, by me and others, but just to reiterate: Be sure you have the right blade to slot alignment and fence to blade alignment (I actually align both the blade and fence to the slot). New or old blade, that alignment is critical.
Dumb question: are there differences between blades meant only to be used in a circ saw and those meant for table saws? Just asking because of the wording on the online descriptions of blades I am looking at. Rlitman seems to have touched upon this issue, but with respect to chop saws, not circular saws.
Maybe 15 or 20 years ago, my folks bought me a Craftsman table saw. This is no high-end machine, but it has worked out reasonably well for me over the years. One thing it does not like to do so well is to rip 2x material. Just today, I was ripping some 2x4x8s into 1 3/4" strips, and I was reminded of the problem. Basically, it feels like the motor or the blade are struggling a little bit. The cut area almost always has burn marks in certain areas, too. I set the cutting guide as straight as I can, using a ruler to measure the distance to the center of different teeth on the blade. I set the height of the blade so that the top-most one is maybe 1/4 or more above the surface of the wood. I don't try to ram the board through, but do provide steady pressure to keep it moving. The blade is the one that came with the machine, stock.
What is the most likely reason for this?
Dull blade?
Dull operator?
Blade height set too low?
Other?
Usually a blade meant for a circular saw will be smaller in diameter like 8" Most table saws are 10" blade capacity. I dont think there is anything inherently wrong with using a smaller blade than the saw can handle as long as the arbor fits correctly.
There are 8" table saw out there and there are smaller circular saws out there. Just replace the blade you have with a similarly sized one.
In my previous post I was trying to slam this point home as well. A dull blade can produce burn marks but if your saw is poorly set up it will ALWAYS produce burn marks. This is why you also need a higher quality fence because once a good fence is set up it will clamp back in to precisely the same position time and time again. A bad fence does not have this kind of repeatable accuracy.
Read it earlier. Great writeup. They do not say whether a circular saw blade can be used in a table saw. The most they say is:
A blade for ripping lumber on a table saw will generally have a high hook angle, where an aggressive, fast cut is usually what you want. Radial arms saws and sliding compound miter saws, on the other hand, require a blade with a very low or negative hook angle, to inhibit overly fast feed rate, binding, and the blade's tendency to try to "climb" the material.
Right, they explain it to you and expect you to understand the explanation, rather than spoon feeding it to you.
While conventional wisdom says the fence must be parallel to the blade in reality what is best is to have the front of the fence .002" to .003" farther out from the blade.
Is this right? I thought it was the other way around, with the back of the blade being a tad bit further from the fence. This way the material has less of a chance of binding as you push it through.
Your attitude blows. Don't bother "helping" me in the future.
You can lead a horse to water. You can tell him to drink. But it doesn't do any good because horses don't speak English.You can lead a horse to water. You can tell him to drink. But it doesn't do any good because horses don't speak English.
"Sorry Bull is a moderator/admin and you are not allowed to ignore him or her."
Sigh.
Re setting blade and fence.
you don't need any fancy tools for that. They are nice and make it somewhat faster, but not better. a few scraps of wood, a clamp or two or maybe a dowel rod or long bolt are all that's needed.
Just attach something to the miter gauge that slides in the table slot. Set it so that it touches the blade either front or rear. Slide and check fit to blade. Adjust blade so that both are the same.
Do the same to the fence.
Drink a cool one, it's lined up.
Odd ... dozens of people saying it's the blade, and not one suggested checking the blade's sharpness.
Yes, what he said. I did not mean you only had to use a dial indicator.
A steel rule graduated in 64ths can work as well.
Get a new thin kerf blade (good quality) and it will be like a new saw! YMMV.
doing alignments with strings (google it), i've learned to appreciate a quality metal steel rule. i prefer metric, but this one has both (one side sae, one mm)
http://www.amazon.com/gp/product/B000SKW1LI/?tag=atomicindus08-20
can't beat the price and it really is a decent piece.
ahm
Home Depot had one Freud 24 tooth carbide ripping blade available, so I grabbed it for around $25. I can't even find the miter slide thing for my saw, so I did not yet do the alignment procedure. But, with the new blade the saw performs much better. No signs of any burning whatsoever, either.
... Basically, it feels like the motor or the blade are struggling a little bit. The cut area almost always has burn marks in certain areas, too. I set the cutting guide as straight as I can, using a ruler to measure the distance to the center of different teeth on the blade. I set the height of the blade so that the top-most one is maybe 1/4 ...
Well I have a different reason for you.
While it may be true that the blade quality is a large factor in ripping a stud I find that the most obvious reason that my expensive Diablo ripping blade does not cut through a stud laterally is not the blade, it is the absense or improper placement of the splitter.
In some cases a different better splitter can be used. You will notice that even after you use a quality blade that the KERF will close around the blade. At any point in the stud if you stop the blade and move the work back and forth the material will pinch onto the blade sides. You will notice that on cheaper higher moisture content wood you get more of this reaction.
