kaptain howdie
the other day I bought a husky 2 hp 30 gal compressor that draws approx 15a 110v. i want to run a dedicated line from my panel to the garage for it since that circuit is close to its max amperage.
now the main panel in the basement is very close to the garage wall, so running the wire will be easier than expected, but after looking at my panel today I have a couple of options.
I have a 30 amp breaker unused and a 60 amp 220v line for a dryer. I don`t have a dryer since my wife likes to hang our laundry so the breaker is off and the outlet is not used.
so i want to use a sub panel but i`m not sure if I should use the 30a circuit, or the 60a 220. I could split the 30a to 2 15`s in the sub box, or use the 220.
the question is if i use the 220v and run it to a sub panel, how do you convert it to 110? I would prefer this option since I will probably be getting a small welder in the future and could use the extra power.
thanks in advance.
thanks in advance.
