darkk
I picked up a new in the box 20 gallon parts cleaner from a garage sale for $50. about a week or so ago. When I get it assembled, what kind of degreaser/cleaning liquid do you recommend?
I work as a hobby mechanic and do some engine work. Cleanliness is high on my agenda, and due ta an accident when I was 19 ( I am 65 now), I can not use petroleum based solvents, since my right hand has very brittle skin and next to no normal nails.
So I have been compelled since a long time ago to find alternatives. The stuff that suits my hands and also does a perfect cleaning job is a liquid vegetable "oil" based on citrus rinds. Scrape off the worst grese/gunk and then submerge the parts in that, do some agitating, brushing every hour and in a day or two he part is spotless. Wash it down with very hot water, blow off water and let it dry off. Spray a very light mist of 5-56 on machined surfaces to prevent surface rust.
And the stuff works on steel, cast iron, brass, copper and aluminium. Use a plastic container when cleaning copper, otherwise there will be some much unwanted electroplating !
In sweden the stuff is called various catchy names like eco-cleaner and what not to drive the price up. I go to a machine shop supply store and buy it in 25 litre can. Obviosly some shops use it as a cutting/cooling fluid at machining as it does not give any allergic reactions.
Ola
