Ok so this past weekend we had some serious rain. Epic rain if you want to call it. I was fortunate not to have my basement flood. I keep the drains well maintained, clean, and all that. My roof is brand new. I put it in myself at no expense spared. Complete tear off, insulation board, cant stips, copper counter-flashing, torch down, etc etc. I do not get any water on the ceilings or walls.
So front of my house is exposed brick, it seems like the water is coming through the brick, and gets right on top of my window casing. Obviously it drips down, and also damaged the wood. I drilled relief holes right away so that the water doesn't collect there.
I went to the roof, in the rain, and put up a tarp, covering about 15' of the roof and about 3-4' of the wall. Nothing changed. Once the rain picked up again, the water dripping picked up too. So it is definitively not the roof.
Ok so fast forward to next day, we get rain again, but this time nothing. And it was heavy rain for a good 20 - 30 min. Nothing, dry as a whistle.
It seems like my brick got saturated, and is then leaking inside my house.
It was re-pointed completely last year. I have masons coming out on Saturday to check all the pointing again, and maybe find the entry point. I hope.
What do you guys think this can be? What should I look for, and what should I do to prevent this from ever happening again? Thanks in advance.
ROOF FACING FRONT OF HOUSE. OLD ROOF BEFORE I REMOVED IT
The house with the garage door open, with the two awnings, and the water is coming into the top most right window.
