Over Garage Door Sheet Goods Storage
nnoble83
Clinton, Oh
I am thinking about building some racks to store my sheet goods over the garage door, i was wondering if any of you guys had opinions on whether or not this is a good idea or if it will too much of a hassle to get too. I am quickly running out of floor and wall space especially since the wife is going to want to park in the garage this winter with the new baby. This is what i am considering building http://www.overallstorage.com/. Between benches, toolboxes, and woodworking equipment i am out of space and need some creative ideas to clean up. Thank you.
Jeff
Sonova Beach
I've often thought of using that space for sheet goods. I don't see any problems using that space, other than the door must be lowered to access the rack.
N
nnoble83
Clinton, Oh
my garage is deep enough that i will be able to access with the door either up or down i'm just a little concerned about handling drywall and 3/4 ply on a step ladder.
dittle fart around
Vancouver, Washington, USA
I'm liking this idea and I've got a bunch of free bee uni-strut. Used to work high voltage substation electrical stuff and we used uni-strut all the time. A chunk on the top across a couple of rafters, all thread down to another chunk and you're set.
Zeke
Yeah, I see that as the major problem. Especially if the ply ins on the bottom of the stack.
I like my sheets to stand against a wall. I can slide out the one I need. But if you're out of wall space, that's gonna be tough.
So, can you think of a way to pull a hinged rack up there with pulleys so that when lowered you can pull a sheet out of the middle?
kbs2244
That is a good place.
But you are talking the wrong stuff to put there.
Sheets are just to clumsy and heavy to put over your head.
That is where my ladders, long handled pool stuff, stick type wood, etc go.
The individual pieces are light enough to handle.
(The ladders do go up one end at a time.)
camarotoolman
cocoa Fl.
Probable need a helper to get much or then 1/4" ply up like that. Maybe stack it out back with some sheet metal over it to keep it dry. Buy an inclosed trailer or storage container they are cheap.
machine_punk
Napa Valley, California
I'm getting ready to build similar storage, but just for my 16 foot aluminum angles, t's, rods, etc. I think the sheet material would be too awkward (I need the bottom sheet on the stack, so I have to remove them all).
HOWEVER, if you could come up with a pulley/winch system to raise and lower the floor, I think you have something there.
73 Mustang Bill
I built this to hold my hurricane plywood panels. I haven't had to take them down since I built this several years ago, and doesn't look like I get to use them this weekend either.
I went up through the drywall ceiling, and nailed into the trusses at the bottom and the top pieces of the truss.
I have a couple window screens stored up there as well, for windows that I never open. If a hurricane is approaching, I take the screens out. They aren't going to stop anything from breaking the windows, and if the window is broken, I'd like to have aa screen that I can put back in to keep the bugs out.
bad_idea
Pasquotank, NC
i attached a shelf from the garage door track to the wall. i stole the idea from a board member, original owner of idea feel free to chime in for credit. i store boards up there. 2x4's etc. i also store my saw horses up there.
i also hung a cut table from the ceiling w/ some brackets. i screw the wood frame down to a pair of saw horses and use it to cut up plywood. also stole that idea from the board somewhere. find it much easier to clamp a guide to the plywood rather than try to wrestle it through a table saw.
i installed theses during this past winter and loved them for convenient storage. then summer hit and the door started being open all the time. it is kind of annoying having to shut the door every time i want a hunk of 2x4 or something. but better than tripping over the stuff when i dont need it.
i agree that the sheet goods should be stored leaning against the wall. if you can't dedicate the space permanently then consider building a narrow, wide cart to roll the sheet goods around on. shove the cart somewhere out of the way when you dont need it, roll it out to access your sheet goods when you do. building a good cart is on my list, in the meantime mine leans against the wall.
JC23
Northcoast
Mine isn't over the door but it could be.
It's made of square, steel tubing. Lemme know if'n you want the details.:thumbup:
4wd4ever
New Westminster BC
I think I saw a bench in Jack's that he has on a pulley system...don't see why that wouldn't work for storage too! I was thinking of stealing the idea for myself!
35mm
Hey gyus, i am just viewing you all conversation. why are you not opt storageo for storing your goods as there are various benefits of it.
I can show you why we have to go with storageo or you can also read it from here, http://storageo.com/Why-Storageo.php
Lets share your views regarding this idea.
Wow, that is exactly the solution I am looking for. I can box up my sheet goods and ship it to their warehouse. When I need them they will ship them back. What a great idea!
cruzer75
JC23 -
How tall are your ceilings? I like the idea of storing stuff up top but would be concerned it would make the shop feel small and confined.
cruzer75
buzz4041
South Texas
JC23 -
Feeling small and being small due to clutter is 2 different things. Get that stuff off the ground and reap the rewards of more space.
bad_idea
Pasquotank, NC
I found (2) carts on CL for moving 8' folding tables for $50. They measure 26x72" base with removable side rails. The base is made of 2x2 1/2x3/16" angle iron, very stout. I am in process of cutting one down to 18x72" to fit where I want it. I plan on storing my sheet goods on that against the wall. When I need to get the sheet in the back I can wheel the cart out and get to it. I will post a pic when I get it done.
hoho98925
East of Seattle
This is my solution using unistrut, all-thread, all-thread anchors.
all-thread anchor
attach allthread anchors to ceiling supporting joists, rafters,or trusses
cut all-thread to desired length screw into anchors. install nut and washer at predetermined distance on all allthread measured from ceiling. install unistrut another nut and washer and tighten up.
It works very well and was cheep, there are different sizes of unistrut and allthread, i know the anchors come in 1/4, 3/8, 1/2" etc, so space your anchors according to the load you plan on it holding.:thumbup:
gahrajmahal
Cincinnati, Ohio
I used some 1" dia. round tuning I had laying around. I drilled some holes in a 2 x 4 and stuck the tubes in the holes. The 2 x 4's are lag bolted to the ceiling framing. Originally it was just to store the screens for the french doors during the winter. But over time a bit of sheet goods and trim moulding has made its way up there too. It has been OK for 15 years, and we stomp around above it because the living space is above. The extension ladder is a 10 footer and is pretty heavy, but it has been very handy having it up and out of the way,
Nowater
Southwest Florida
Be cautious if you are suspending the rack form the bottom chord of roof trusses. Roof trusses are designed to hold weight from the roof, and not from the bottom. The same problem arises if one stores on an attic floor made from trusses, unless the trusses are designed for a storage load. If you must store there, watch the weight, and I say that only because I think many people will ignore this advice anyhow. I didn't believe it the first time I heard of it either. Just sayin.
