I am watching your Thread, so keep taking Pics and Good Luck!
I did have a good friend who had an old 2 story house that the Main Floor Joists settled and his kitchen floor slanted.
He had bought a large I Beam, cut a hole in the side of his basement stone wall, slid the beam though all the way to the other side (Had to torch off the 10" or so that was left out), using (2) 7 ton floor jacks and 6X6 Posts, jacked up the Beam against the floor (slowly) until it was within 1/2". Then placed JackPosts in each end, Sistered up the bad Floor Joists and finished the Stone walls. (every week turned the Jacks 1/4 turn until plumb)
House made some crazy sounds while all this was going on, and he had to do some plaster work on the walls upstairs, but it worked out great and that was over 25 years ago.
When I realized the floor was bowed, I considered the possibility of jacking the building to get it square again. That obviously would be the ideal solution, but the walls have settled because whatever they're built on has compacted. I was worried by jacking them up I'd fix the bow in the floor but have walls bearing on nothing.
This building had a gravel floor until the previous owner poured a slab inside it. I have no idea what kind of footers (if any) are in place, although when I hackjammered out the floor for this project I came across some cool square stones which were probably a foundation (at some point).
Seems to me that shimming is the safest thing to do; I'd hate to open a pandora's box trying to move the whole building. Who knows, once I move those posts, it might sink a bit in the middle anyways.
And here's a (bad) pic of the first column:
