How to clean rusty nuts,bolts,washers??
rkevins
Central Arkansas
I have a bunch of nuts, bolts, washers that have been laying around in the floor of a old chicken house exposed to moisture and ammonia. I am trying to find a way to clean them up, any ideas on something to soak them in.
muriatic acid solution, lye and water, vinegar, citric acid, (that's just a list of some of the things I have around) any ideas would be a great help.
Thanks Kevin
BJ42LX
WNY
Evaporust is great for nuts and bolts. Just drop them in and come back a day or two later. Maybe brush with a stiff brush a couple times in between.
Stuart in MN
Minneapolis
I would suggest trying out the search function here on the forum - there are usually a couple discussions every week about different methods of rust removal.
Since you're talking about nuts and bolts, make sure you don't spend more time and money cleaning them up than they're worth.
The Hot Rod Grille
Winfield, WV
I use a tumbler (the type used to polish shell casings). Several different types of media are available, depending on how abrasive the material must be to remove the oxidation/rust. Walnut shells does a nice job on most surfaces.
Jim
Marmaduke
I would say the nuts and bolts laying on a chicken coop floor for years are not worth the price of the cleaning fluid. Throw them out DAD:lol_hitti
camarotoolman
cocoa Fl.
I have boxes and boxes of old nut/bolts. But when I need one, I don't have the right one so I have to go buy one which ***** when its 8 mile to the store. Price of scrap is up rigt now...
D.J.
New Haven IL
Please don't use the wire brush method. Don't forget about your friend histaplasmosis, you can loose about 40 pounds and think you are going to die along with fevers, profuse sweating even in cool weather! Just ask me how I know?
D.J.
70redbee
Knoxville,Md
Just throw them in a bucket of vinegar. When you take them out just wash them in water and baking soda. Or throw them away and buy new ones.
mikec35
NC
I use a vibratory tumbler I bought from Harbor Freight- works great
Zrexxer
Pflugerville, TX
THIS.
I'm always amazed at the great lengths people will go to to achieve false economy. Cleaning rusty hardware that's been laying on the floor of a henhouse caked in chickenshit? No way. I'd pay the price for little plastic bags of nuts at Home Cheapo before I did that.
R
rkevins
Central Arkansas
THIS.
Sorry for the confusion, I never said they were in the house when it was in use, it was shutdown and used as a shop and for storage the bolts nuts were laying on a tarp not on the floor but the remaining litter still causes amonia and will for years to come
Thanks to all who replied
Kevin
brownbagg
metal bucket, battery charger, piece of scrap metal, copper works good and some oxy clean
oldgoaly
Shiloh, Il
old or cheap crock pot with molasess, only the rust gets eaten up. You will be surprised how well it works. only down side is when you rinse oil or metal prep/phosphoric acid or they flash rust in minutes.
kyles974
Florida/Alabama
THIS.
myself, I would clean them up if they were "good old metal" nuts and bolts.
.....have you ever priced a good quality nut and bolt? Grade 8?
we both don't know what grade these are, but just a thought:thumbup:
Zeke
Please don't use the wire brush method. Don't forget about your friend histaplasmosis (sic) , you can loose about 40 pounds and think you are going to die along with fevers, profuse sweating even in cool weather! Just ask me how I know?
D.J.
Histoplasmosis. Never heard of it os I looked it up. No, I guess I wouldn't wire wheel nuts and bolts from the bottom of a chicken coup. Histoplasmosis notwithstanding.
35chevypu
vt
great! now the wives gonna wonder where the spare crock pot went and why did it end up in the garage.:lol_hitti
Zrexxer
Pflugerville, TX
Yep, I have. I spent too long trying to make do with mismatched, rusty, discarded hardware. Now I've been buying good quality hardware for 20+ years, and it turns out it's always cheaper than the time it would take me to try and make do with someone else's castoffs.
Time is the most valuable asset I have. YMMV.
93sr20det
Gulfport Ms
I use this same model crock pot with old antifreeze in it. I let my bolts simmer overnight then rinse them off and they turn out pretty good.
dellwas
Chester Grant, Nova Scotia, Canada
Thanks for the tip, must give this a try...
I use this same model crock ot with old antifreeze in it. I let my bolts simmer overnight then rinse them off and they turn out pretty good.
knight
Place them in a bucket of water, cover the lid, then let them rust out completely. Mix this iron-enriched water with fresh water, then feed your lawn and plants it. They love the iron and it's a lot cheaper than a $7 bag of Iron fertilizer. This is what I do with old rusting nails
IH82BL8
Bowie, Md
THIS.
In my case I was rebuilding an engine, so I was having a lot of exterior brackets replated anyway. Yeah I would clean up a fastener that I could replace cheap.
