blue dog
I DID NOT BUILD THESE....
...but I wish I had...they look awesome.:
I want to know what these sound like, and how long it took to lay out and fabricate. beautiful.
This is the exhaust system I made for my LT1 powered MGB project. I want the car low so I needed to tuck the exhaust up into the car for ground clearance. The headers run into 2 1/2" tubes that run along side of the transmission. I had to make an ovalized 1 1/4" section to go under the clutch release mechanism on the bell housing. The pipes join into a 3" pipe which ovalizes to a 1 3/4" section to go under the Corvette center section. The lowest point of the exhaust is only 1/2" below the level of the unibody subframe at the lowest point.
Wow Jim! Thats a MAJOR exaust!
Being able to invert the car is a major bonus when it comes to making stuff for the under side. That's cool
Worked on this last year for a project at school. I got to weld the frame and design the rear aluminum subframe
These are a few of the tube projects I have done. I really need to get better at taking more pictures of finished projects.
My first header built back in 05. It turned out nice, I wasn't happy with the collector, but I learned a lot. The turbo manifold and down pipe I built and then ran successfully on my road race car. The front cross member was also on the Civic, it relocated the front pickup points, radiator and transmission mount, plus it weighed less than the stock piece. The cart is a project I built for the UAH softball team, it was designed for carry softballs out to the field. The half finished CRX roll cage was actually finished and sent on to the customer, I need to get more pics of it. The other car is an RX8 built to run in Grand Am.
Some motorcycle bits from the last few months:
Hardtail CB350 frame
A one off swing arm for a race bike with Monoshock conversion:
A few more tubular projects from here and there...
![221675_220304131329800_100000506430131_923966_7252679_n[1].jpg 221675_220304131329800_100000506430131_923966_7252679_n[1].jpg](https://www.garagejournal.com/forum/data/attachments/95/95929-63d3f1ea96362b5ca75721fe689accd2.jpg)
![230024_223275767699303_100000506430131_947445_2166140_n[1].jpg 230024_223275767699303_100000506430131_947445_2166140_n[1].jpg](https://www.garagejournal.com/forum/data/attachments/95/95957-145d9da84211b26c155919717be59691.jpg)
A turbo collector.
My integra fully stainless exhaust, downpipe, turbo manifold. Aluminum intercooler pipings. Etc etc.
But heres a picture of a ceramic coated, stainless headers i fabbed up. Could have been prettier on the welds, but 1 single thick root pass was my goal, instead of a root and cap. (not interested in welding a pretty pass)
Here's some of my stuff from about 6 years ago. All of it is from my twin turbo '72 Vega.
I hadn't welded anything for about 20 years.
Bought a welder, opened the box and built this ladder rack the 1st day.
Used schedule 40 fire sprinkler pipe.
I 'load tested' it with about 40 20' 2X4's. Guess it will hold up to
the ladder I carry everyday.
NOT even in the same class, exhaust for our 1969 Impala 427. 316 16 ga. Stainless, Stainless FlowMaster 40's. Sounds awesome.![]()
Nastyzen, back in the day, did anyone use 4130 for chassis or fabricated parts ?
I wish i could come hang out at your shop and soak in some knowledge, you seem to have been around the block a few times when it comes to this stuff. I commend you sir, as what you do is a lost art.![]()
More info and pics on this. That looks really cool.
Nastyzen- Do you have any more info or build pics of that #66 race car? I know NOTHING about those cars, but that "finished" pic knocked the wind out of me. Easily the sexiest roadster i've ever seen...
...think they'd let me take the wife out on a date in it?![]()
