WhiteTrash
- Joined
- Oct 13, 2010
- Messages
- 155
I wouldn't hang a mower on the wall unless it was electric. They don't tend to like it much. But you can loosen the bolts securing the handle and fold it over on itself. Is it easier to store under things.
Over head cabinets on the side walls are great ways to add additional storage, but I see overhead space is limited. You can run them between the back wall and the garage door rails. They also provide a convenient place to hang a light over a workbench or frame a pegboard backing above the workbench.
Personally, I would move the decorations into the attic. I am a firm believer that the only things that belong in a garage are things used in the garage. The scrap plywood could be used to make a flooring over the joists up there. It would also give you twice a year to go into the attic and checking things up there. Making sure the insulation is adequate and no critters have moved in. While you are up there, you could drop a a few more outlets for use in the garage. Place one for the sprinkler system and a few on the wall for your workbench.
When do you plan on starting the shed? Also, always go bigger than you think you will need. It will always get used and appreciated. I don't know anyone who ever said they wish they built a smaller shed, but I hear it the other way around.
And it seems we are practically neighbors as well. I am down in the Waxahachie area. If you find that you need help with anything, let me know.
And that is a tough choice between the bike and the car in the garage. Ultimately, I would choose the bike.
And maybe I can squeeze a wide narrow "cookie sheet" type storage drawer under the right and left sections.
