How do you store your chain saws?
dreamingmuscle
Tryon Oklahoma
I'm tired of my chainsaws leaking bar oil when they are stored. I know I could empty it out. But that would be a pain in it self.
So how do you store your chain saws to keep them from making a mess?
Glen
BigSteve63
SW Missouri
I use one of those aluminum baking pans from the dollar store. I just set the engine down onto the pan and let it settle itself in. Catches what little bar oil that comes out and protects the shelving material.
5lima30
Mountains of Western NC
I keep mine in their plastic case they came with. I keep newspapers inside the case to absorb the bar oil. I change the news papers as needed. Worked for me for years. YMMV.
R-132 Fan
Central Texas, East of Austin
Have you tried laying them on the side with the chain down? I have a Stihl MS210 that will leave a puddle of chain oil if it sits upright, but no leaks when laying on it's side.
therealwormey
one of my stihl leaks and one dont,half lucky,,i have a lid off a big plastic container that i busted so now the lid is upside down and the saws sit on it
deranged
Lima, OH
I read a trick the other day that I haven't tried yet, my Husq leaks bad, and from the trick that I read, said that the crankshaft pressurizes the oil reservoir to pump the oil out. So to help with leaks after you shut the engine down you're supposed to open the oil reservoir to relieve the residual pressure. Put the cap back on and you're supposedly good to go.
Not sure if that applies to all saws, or if it even helps, just something I read.
trbomax
starvation lake,mi.
Ive got 3 stihls and one husq,they all leak.I keep them in the cases and use the newspaper or a hand towel under them. I dont know about all husq saws,but mine has a oil pump,not crankcase pressure.
edit) make that 4 stihls,I forgot about the pole saw,but it leaks too.
tcsalvage
brogue, pa
i have a pair of 034 supers and one leaks one doesn't so i just run them both out before i store them. i also have a 50v john deere but the fill caps are on the top of the saw so it doesn't leak. they all stay locked up on one shelf with the demo saws.
D
dreamingmuscle
Tryon Oklahoma
I have both a Stil and a Husqvarna. I haven't had time to find out if the Husqvarna leaks yet. But I will try the trick above on the Stil.
I like the cookie pan idea.
Now laying it on the chain side doesn't make sense to me. Because that is where the chain is and gravity should still force it out. But I'm going to try all three of the above.
Thanks Glen
srmofo
SW ohio
I was unaware that chainsaws didnt leak oil. Every one I have ever owned leaked bar oil. newspaper and plastic case for me. I Will have to try opening the cap when done and see if that makes a difference.
79firebird
Victoria bc
Hmm I use to have 5 saws now i have 1. None ever leaked. Mind you after finished using them i allways cleaned them well. Compressor and parts washer to clean it all up.
chevyc10
I store mine by the bar hanging on the wall as i didn't get a case. I don't get any leaks that way when sitting flat it did. I started storing it on the was as ran out of shelf space but had some wall space by the over head doors.
Marmaduke
Well I'm glad I don't have the only Stihl and a Poulan the leaks bar oil all over the place, I have taken them apart and can't find any reason they should leak. I just keep them in a pan for storage. The real pain is when you are using them any where you put them down gets oil on it.
Lippyp
Shropshire, UK
Mines on a shelf now with the oil can, gas can etc next to it, even the little spanner/screwdriver jobby has its own little hole to keep it safe, its sat on a piece of brown cardboard from a box to soak up the little oil that leaks out.
Plump
SE Wisconsin
I use these Pig Mats: www.newpig.com/us/ and just have my saw on a shelf in the shed. They work great for working on the car, snowblower, etc. as well as keeping the drips when I defrost the kegerator from causing a mess.
fr0mastaj
phew, i thought i just had a lemon. Glad to hear it seems to be the norm. My plastic box for my husky has a pool of bar oil on the bottom!
premierplayer
Maryland, USA
Couple pieces of cardboard under, it lives on the end of a formica workbench top with all its necessitys, if the cardboard soaks through, no biggie.
Previous saw lived in the plastic case with a rag or two in the bottom for collection.
I've never experienced a saw that didn't drip bar oil, some more than others mind you.
jerseywild
Lynden, WA
My husqvarna nor my stihl do not leak. Guess I am lucky.
All my Stihl saws leak oil. I have 8 right now and about a dozen other stihl saws over the years and all have leaked oil. I sit them on oil absorbent pads that I get from the NAPA store. Pig is the brand of absobent. They will leak through so I place a corragated plastic sign under the absorbent.
some zilch
neither my ms290, 044av, or ts400 leak a drop of oil. i cant imagine a chainsaw leaking enough oil to even bat an eye at
Mattlt
MN
Might want to compare brands of bar oil. I've noticed that some of the cheap stuff is more like plain motor oil, while the brand-name stuff is more like pancake syrup. With bar oil sticky is good.
I've always considered some leakage normal too. Usually, with my luck, the saw doesn't oil the bar properly, then when I set it on the shelf/floor and come back an hour later there's a puddle under it. :-(
trbomax
starvation lake,mi.
Get some adult matteress diapers at the drug store. When our oldest dog (17) started loseing it at night we used them.
edit) i keep them around for changeing side mounted oil filters and when doing chaincase service on the sleds.
Warrenator
Newberg, OR
I have 2 chainsaws, one leaks, I just don't keep oil in it. Oil it very well with Bar Oil in a oil pump squirt bottle before and after each use, call it good.
MoonRise
Plastic chainsaw case. Contains the drip(s) from the bar/chain oil, and the bar 'scabbard' also keeps the chain from crudding up or 'snagging' on things. Also, just grab-n-go the case (with saw, spare chains, skrench, etc) if I need to go somewhere with the saw.
One saw came with the case, OEM. Other one I think I got an aftermarket case.
The little electric that I hardly ever use I just let all the bar-n-chain oil leak out and then put it wherever on some newspapers. Just refill the bar-n-chain oil if/when I use it (I think the last use was squaring off the end of a Christmas tree, which didn't warrant the 'big' saw).
obtw, mpire, that movie was just on cable up here the other day. Dino DeLaurentis and cheesy effects galore. :D Was channel-flipping and paused to watch a little bit.
MN4x4
Minnesnowta
I used to just leave mine in the Zombies, but I found out that their blood made it rust....
JCQuick
Apopka Fla.
I keep mine in its case as well with absorbent(aka pig mat) pad under it.
If I hadn't just lost my job i would offer up a deal to GJ members on the pads but can't do it now. theres a pretty good markup on those I would buy several pallet loads at a time and pay about $16.00 per 100. we sold them anywhere from 23.00 -45.00 per 100
coffeebean
SoCal
i store my personal saw(Husky) dry. run the gas out of carbs too. it would leak a lot if i didn't because i have the oilier set wide open a lot.
the saws at work (Stihl) leak some. but we set the oiliers to heavily oil in cold weather. that way we know we'll get enough anytime. we clean a lot.
make sure your oilier is set appropriately for the job at hand. it may leak less if you adjust down. just make sure you have enough oil getting to the chain.
dave
D
dreamingmuscle
Tryon Oklahoma
Well I finally found a solution to my problem. My son found a little metal shelf with three shelves including the top. So I turned it over so the pan shape was facing up. Works real well. My two saws sit on the two bottom shelves and my saw tool box and bar oil sit on the top one. They still leak some but I'm draining the bar oil before I store them.
Falcon67
Merkel, TX
My Craftsman 18" leaks - I keep it in the plastic case it came with and lay it on it's side. Not that big a deal but it is annoying. I'd like the bar oil tank designer to sit on the sharp end of the saw while he/she explains WTF they were thinking.
