I need to run a 230V outlet to my garage for a compressor that I'm getting next week. It's a Quincy 251CP80VCB:
http://www.northerntool.com/shop/tools/product_200451863_200451863
The compressor draws 23A under constant load but draws a lot on start up according to Larry at Quincy.
At some point down the road, I'll end up with a welder like the Hobart Ironman 230:
http://www.northerntool.com/shop/tools/product_47864_47864
The welder draws 32.5A at 230v.
I have a sub-panel in the unfinished basement and will run the line to the shared wall between the basement/garage. The length of wire would be about 30 feet.
I spoke with Hobart today and they stated that I needed to run a 6/2 line. The welder comes with a Nema 6-50 6 foot plug wired at the factory. I stopped by a farm store today and saw this welder and was surprised that the wire used in the 6' plug was 12G.
I spoke with Quincy yesterday and they recommend 10/2 for a short run and 8/2 for a long run to power the outlet where the compressor will be hooked up. I didn't ask what the distance equated to but since I want to eventually have the ability to power both (not at same time), I will run 6 gauge wire.
Now here are the questions:
1-Since this is likely to only things that the 230V circuit will power, would running 6/3 be a waste?
Since the Hobart is a Nema 6-50 male plug, I need a 6-50 female plug. I didn't see this at Home Depot but maybe Lowe's will have this. I need to wire the compressor to this outlet and would rather get a wire w/plug already made. I don't see myself moving this compressor around so it will likely stay about 10-12' from the plug. (Quincy recommended hard wiring this but for my application I'd prefer a wire w/plug).
2-Where to get a plug/wire setup and what gauge? (I'll be running 6/2 likely from the sub-panel to the garage outlet. (Home Depot had 12,10,8 and 6 SOO wire (3 strands) readily available.
Anything that I am missing? Thanks for the help.
