I have a Genie Blue Max CM-8500S garage door opener. It will not close the door all the way without opening back up. I checked that the sensor does not blink at all and the door passes the balance test (it closes and opens by hand easily). I can't find a manual online. Can somebody tell me if there an adjustment screw for closing force? I looked all over the unit, but hopefully I'm just missing it. Thank you.
Since I first posted, I found where the two adjustment open and close screws should be. This model just has the holes in the metal plate. Just for the hell of it, I adjusted the nylon nut behind the motor at the end of the shaft with no results. Any help is appreciated.
Well, from everything I have read since my last edit, I have to adjust the closing force. But since that is not an option for my opener I guess I will have to replace it. Anybody?
