LM Sidekick Multi Tool
Stuey
28m above sea level
Leatherman Sidekick Review
Leatherman is coming out with 2 new multi-tools, the Sidekick ($40), and Wingman($30).
I reviewed the Sidekick (link above), and was initially concerned about what effect "entry-level" and "value-priced" would have on the tool's quality. After a few minutes, it was clear - the Sidekick rocks! :thumbup:
Pros:
inexpensive
spring pliers
nice Phillips tip
good build quality, decent tool latches
Cons:
wire cutters are weak due to simpler design
smooth one-handed opening is difficult
Closeup photos are posted on the blog, as is a more in-depth review of the tool - Leatherman Sidekick Review (via TG)
It's definitely a good buy at $40, and the Wingman has great appeal as well at an even lower pricepoint.
Disclosure: The sample was provided at no-cost unconditionally.
Stuey
28m above sea level
I want to see one in person, but don't plan to buy one because I am more than happy with my ST300.
The ST300 is a nice tool as well, but suits different purposes.
You might not want to see one in person if you don't want to be compelled to part with some cash. It's a really, really convincing tool, more so than some of LM's higher-end tools, imho.
Omphaloskeptic
Ultima Ratio, Wa.
You might enjoy 'Nutinfancy's YouTube video overview at the Leatherman booth at the recent ShotShow. He's what you might call an enthusiastic independent reviewer. lol
Stuey
28m above sea level
Update: the knife becomes easier to open with use.
Loosening the pivot bolt slightly did the trick as well, but I didn't like how loose it made the knife, so I tightened it back up.
Lippyp
Shropshire, UK
I love my leatherman wave, gets used all the time. I would buy a cheaper one though to leave in the glovebox.
slipjointed
I like it, but until they come to accept the fact that left-handers do indeed exist, I won't be buying any.
Stuey
28m above sea level
I wonder how it will compare fit and finish wise to my Victorinox Spirit. Any word on its COO?
It's made in the USA. No word if global materials are used, but Leatherman was very adament about describing it as value-priced while still made in the USA in Oregon. So I assume that from start to finish it's made here.
All my Victorinox are of the pocket-knife style, so I can't compare, sorry.
jeffmoss26
Cleveland, Ohio
Well I bit the bullet and bought a Wingman. It's being laser engraved with my name as we speak. More details to follow, so far I like it. I was able to use an old Leatherman Kick/Fuse case for it, since they do not have a specific one.
Stuey
28m above sea level
I bought a Wingman too.
Right before I wrote about the Wingman deal on TG. :bounce:
I checked the local HD yesterday, and the display is almost sold out. Could be that someone bought many to resell.
IndyGarage
Indy
I saw this thread and went out to get a Wingman on the way home. Picked it up at HD for only $24.95
It seems like exactly what I've been looking for to replace my Juice S2. The Juice has been perfect except for a couple things I didn't like - 1. The blades didn't lock. 2. The scissors - my most used tool, didn't open directly - you had to open the canopener - my least used tool - to get to the scissors. and 3. The knife blade on the Juice seemed a little soft.
So I've now got the Wingman sitting side by side with my Juice and my new model Wave. Here's my comparison between the three:
Leatherman Wingman vs. Juice S2 vs. Leatherman new Wave
Size: The Wingman is between the two in size, but much closer to the Wave than the Juice.
Pliers- Wingman and Wave pliers are the same size, which is about 40% larger than the Juice pliers - which is better. I really like the spring opening from the Wingman. Juice nor Wave has it. The wire cutters on the Wingman are shorter segment than the Wave - which won't be a problem for me, because I use it rarely. The serrations on the forward part of the jaw on the wingman are coarser than the Juice or wave. I love the spring opening pliers on the Wingman
Knife Blade - Wingman blade is about 10% longer than the Juice and much more substantial. Wave Blade is another 15% longer and even more substantial. Juice doesn't Lock, both Wingman and Wave do, and both of them also have a thumb hole for single handed opening. I can do it on the Wingman, but the Wave mechanisms have a higher quality feel to them and the Steel seems to be a bit harder than used on the Juice..
Scissors - my most used tool. Interestingly this is where the Juice S-2 shines. The scissors have the longest cutting edge of the 3. The only flaw with the Juice scissors are they are hidden behind the can opener. The Wingman has it's sicissors located in a prime spot on the outside of the tool, they open easily and they lock into place. The Wave scissors are next to useless. They are located inside the tool and stored with the blades open with little used accessories. Additionally, the wave scissors blades are so small as to be only used in the least demanding situations.
Ergonomics - as far I am concerned, the Juice is the most compact and useful nearly full-size multitool on the market for nearly 15 years. It's a fantastic combination of tools and small size that I've been very happy with and carry in my pocket evey day. . I've always "lived" with the way the Juice handle feels. The anodized colorful aluminum handles have a sharp edge to them and it's not very comfortable. Also, the two sides are not the same thickness, which is a bit annoying - this is clearly the weak point of the Juice. The wingman handle feel is better than the Juice in that the sharp edges are folded over, but they still exist, so it's not perfect. Neither one of them are in the same league as the Wave - which has the best handles I've felt on a multitool - nicely rounded with no sharp edges. Another reason the Wave feels good is that the "pliers closed" handle angle on it is a bit sharper than the others, allowing your hand to close around it a little tighter.
Additional blades/tools - Both the Juice S-2 and the Wingman have a nice selection of basic needed tools in addition to the pliers, knife and scissors. The Juice tools are significantly lighter weight - however the Juice I'm looking at has been in my pocket for about 7 years and used in every way possible, and none of the tools are broken or damaged (scratched up, yes, damaged? no). None of the "other tools on either the Juice or the Wingman have locking mechanisms. As far as accessories - the Wave is absolutely the big kahuna of this group - it has a huge file and a similar sized wood saw, it has a large serrated knife, It has a it has a replaceable tool bit system in both large and eyeglasses size, and all the tools lock down tight until you unlock them.
weight - I was curious, so I pulled out my postal scale and weighed them:
Leatherman Juice S-2, 4.4 ounces
Leatherman Wingman - 6.8 ounces (with the pocket clip attached)
Leatherman Wave - 8.5 ounces
So what's the bottom line? I think the Juice S-2 is still a very competent pocket multitool. It's still a brilliant design after 15 years or so, being about the size of the Uncle Henry my father always carried. The lack of locking blades makes it seem a bit outdated.
The Leatherman Wave is the best multitool I've owned - and that's among dozens. If I were stranded anywhere in the world, this is the multitool I want to have with me - however it's too big and too heavy to keep it in your pocket and it costs around $75.
The Leatherman Wingman is a fantastic bargain, and looks like it's going to be a great tool. I paid $39.99 on sale for my last Juice S2, and the Wingman is a much more substantial and capable tool, and the steal of the week at $25. It gives 90% of the real world capability of the Wave in a lighter and much cheaper design. I'm going back to the Depot to get some for holiday gifts.
I bought both a Skeletool and a Freestyle from Leatherman when they came out, trying to find that perfect replacement for my trusty Juice, but they both seemed to be more about form than function, and I'm all about function and not much about form. They look great, but they didn't deliver the performance I was looking for.
I think this Wingman might be the one to replace the Juice in my pocket. It's a bit larger and heavier, which I might not like - I'm going to try it for a couple weeks.
IndyGarage
Indy
Used the Wingman last night as I made my rounds of home fixits.
The only thing I don't like so far is that they made it so you have to hold the handle one way when using the pliers.
It has a very slight outward bend at the very end of one side of the handle. I'm not sure if this is simply a styling thing or not, but the corner of it digs into the palm of your hand when you pull hard on the pliers, so you have to hold the tool with the other side facing your palm.
Those are the kind of really imperceptible ergonomics that you'll never realize until you start using the tool.
Did I say I really like the spring open pliers? I really like the spring open pliers. I was trying to figure out where the spring is and I can't find it. They've completely hidden it inside the hinge.
