First I know this has been hashed, rehashed, and beat to death. I've been going through all, or most, of the searches on lifts and you would think that would make up my mind. Well, I guess I'm just really hard headed or too tight to make the right decision.
I've been looking at the Atlas Pro 8K XLT and the Bend Pak HD-9XW. It probably is insulting to BP to compare this lift with their product. If money were no object I would buy the BP and never give it a thought. As with most people though money is always an issue. It's not really the price of the lift itself it's the accessory prices being added on that take it a little over the top. So thinking out loud here are what I see as pros and cons.
Atlas:
Cons : Not certified
I don't like how the cables are mounted on the columns
It's black
Pros: obviously price
It comes with most of the extras I want
Most of the extras, like jacks, are also less expensive
GSE is local and I can go pick it up with no shipping
Bend Pak:
Cons: Price
It has to be shipped and special arrangements made for pick up
The accessories add a lot to the overall cost
Pros: It's certified
I like the design better(columns)
It's blue
It has a little higher capacity. Though I probably will not really need that.
After the amount of money I've spent raising the garage this spring money is tight because of cost overruns. The $1000 difference in price would go a long way for epoxy coating for the floor. The budget was supposed to be with a lift included but I ended up using some of that on the garage itself. So, I know to some this is a no brainer but I'm having a really difficult time with it. Any suggestions from all of you on what you would do given the situation? I would like to get one before winter and specifically designed the building to accommodate a lift. Suggestions?
Atlas:
It's black
Bend Pak:
Cons: Price
It's blue
