why no more round shank wrenches?
senlow
Wheat Ridge, Colorado
Moose hit the nail on the head. Oval or rectangular beams are stronger.
Of course, I would take a round beam over the Craftsman Crossfarce any day.
Thedroid
New Mexico
We have a huge Wright round beam at work. 2 7/8 I believe. Its probably 40 or 50 yrs old, and heavy duty.
dede2897234
Northern, Ohio
Can someone please post pictures of your wrenches with a round and an oval beam profile? I cannot picture it in my mind.
Thanks,
Dave
stewart
long island NY
Yeah the flat is stronger in one direction (the one it's needed in), easier to forge, but best of all when your arm is up in there between the exhaust manifold and the Z bar and you can't see the fastener your working on you know by feel the plane the wrench end is in. 12 point is handy here too.
My Dad has some of them round beams, they're good quality, I'll guess they were easier to forge from available round stock. You make them with smaller dies and a lot less tonnage.
Packard V8
Spokane, WA
There's a like-new Wright round-beam combination, approx 1-1/2", at a liquidation center near here and the price is right. I have to fight myself to keep from buying it every time I'm in there. I have no need for it, but I'll be disappointed when someone else buys it. They just look heavy-duty!
thnx, jack vines
DrkMtnDew
these are some of my older blue points, the smallest is round and the other two are more oval.
John in OH
SE Ohio & Eastern Virginia
Attached are several photos of one of only a few round-shanked wrenches that I have, but this one is a good example of how these wrenches are made. This one is also somewhat unique as it has 8-point ends, but that's not relevant to the shank design.
It seems that Blue Point and Wright used this design extensively ... maybe others as well. As others have mentioned, the round shank may not have as much strength as an oval shank. but it does have a nice feel.
I had never before heard that the round shank design was banned.
Packard V8
Spokane, WA
Do you see any round shank conrods in engines?
Round shank connecting rods were used in the Miller and Offenhauser racing engines which won Indianapolis for forty years. If it were possible to forge a hollow tube shank on the rod instead of having to drill it, we might still be seeing them today.
Wrenches and con rods are not apples/apples. Yes, the flat beam is stronger than a round bar for the same weight when the bending force is applied laterally in line with the wide side of the beam. A connecting rod needs its greatest strength in tension, because they usually fail by being pulled apart by high-RPM inertial forces. I'm told a tube has the greatest strength/weight in tension.
jack vines
Danglerb
SoCal
jack vines
I've never seen a rod pulled apart, but plenty of the S version. Maybe these days detonation is more of an issue than high RPM?
Guy in our town when I was growing up had a Boss 302 they put crazy money into, story was it had "Indy" rods made of titanium tubes in a triangle fashion.
Have you ever saw I beam pushrods in an engine?
MUCH much lower force, and no real lateral force, so nothing but tubes as far as I know to keep weight to a minimum.
Anybody know why performance rods come in two basically different I beam orientations? Now I see a lot like these.
  • turp_0812_03_z+latest_car_products_nissan_gtr+carrillo_connecting_rods.jpg
SNIP
Those have a much better weight to strength ratio, but are more expensive so generally only Hipo motor builders use them. IIR they are also supposed to have better aerodynamics at speed than the traditional I beam rods, but that could also have been just speed shop hype....
ND400
Australia
It's Cheaper to build a strong H-beam than an I-beam. However a top notch I-beam will weigh less than a H-beam. Less reciprocating mass faster engine acceleration.
Here is my only example of a round shank wrench:
Probably 1930's Hinsdale (Chicago USA) double box wrench.
Pretty average quality for the era, but not junk.
scott0
Frederick, MD
H beam rods like the one pictured are usually cheaper to produce and lighter than their I beam counterparts. However they are not nearly as strong. In a high revving turbocharged engine you will port a block with a h beam long before you will ever have a I beam fail you. I am referring to both rods being aftermarket and both being forged.
P.s. those round shank wrenches look super comfortable!
