The Dutchman
I'm an auto mechanic here in Pennsy & was drilling through steel a while back, on a car I was repairing, & encountered, about halfway through the material, a squealing/ringing sound. The bit kept turning, but stopped progressing. One of the guys, who had been a metal fabricator, told me that the squealing sound indicated metal that was too hard for the bit in question & that I was screwed. I finished the job somehow & figured that I had run the bit too fast, applied too much pressure, or maybe the bit was on its last legs to begin with.
2 days ago I was drilling frozen bolts out of an exhaust pipe flange with a brand new Snap On cobalt. I ran the drill slow, kept it cool, & didn't use too much pressure. About halfway through I heard the dreaded squealing sound again & the bit continued to turn, but basically stopped progressing. I got through with a carbide burr, but the result was a butchered hole, since I guess the burrs aren't as "precise" as a fluted twist drill bit.
So I wanna get some carbide tipped bits. Checked out a 29 Pc set online, 1/16" to 1/2", with 1/64" increments. 5 bills. Oh, Mama! So I decided on just 6 bits: 1/8", 5/32", 3/16", 1/4", 5/16", & 3/8".
I can't decide if I want 118 degree or 135 degree split point. I always use a pilot hole, so maybe the split point, whose advantage is that it stays centered, might be unnecessary. Also, I gather that the 118 degree bits require less pressure on the hand drill to cut, what with their more "pointed" angle--I'm 60, & my arm gets tired quick pushing on that drill!
Any thoughts re 118 vs 135?
