Hitachi Nailers, opinions?
rtoms
sitting next to my buddy who does carpentry for a living and loves em, has 4 guns, 16 an 18 gauge finish nailers and full round head framing gun and a crown stapler and loves em all.
robertwhite
Aren't they made in Japan?
Isn't every nail gun sold in the USA? (maybe not Japan, but Asia)
As for the Hitachi guns, I have trim, staple, finish, etc. and all are 100% reliable. The only thing you need to watch for is when trying to use Bostich nails (especially finish). They aren't identical and will make the gun malfunction. Stick with the Hitachi nails and you are good to go.
Now if this questions goes into the framing nailer scene, Bostich is the ONLY gun worth a look.
Mr Ratchet
Hitachi is one of the better nailer companies. I put them right up there with Paslode, Senco, and Bostich. They have good quality and durability.
GeorgiaHybrid
Extreme NW Georgia
As long as you have a round head Hitachi framing nailer, you should not have a problem. I will agree the Hitachi clip head nailer is not the best though.
R
Recoil Rob
NY
So, for a finish head nailer I have to use only Hitachi nails? Around here they are not readily available, will anything else work?
thanks, Rob
teleman37
Newcastle, Wyoming
I love my Hitachi full head framing nailer! I built my entire shop with it....over ten thousand nails through it so far and not a hiccup one.
Mike F
Long Island, NY
I have that nailer and have put more than 6000 nails in with it. It is reliable, seems durable, and has never jammed on me. You can use any nails compatible with the gun. I needed stainless nails, which were not hitachi brand.
robertwhite
thanks, Rob
You just have to make sure the package says they are compatible. There is some kind of difference in the way the Bostitch and Hitachi finish nails are linked (wire vs.?) and the Bostitch wouldn't feed. You can get the Hitachi nails in any Lowes and most lumber stores.
robertwhite
I certainly wont argue about the full head framer being a good gun, but I went thru a trial run of several brands and the Bostitch won hands down. There has to be a reason why Bostich frame guns are on the vast majority of worksites all over the world.
MrMark
Southern Cal.
Not around here. Hitachi framers are the standard on the West coast. I've never even seen a Bostich.
As for the question, I have that 15 gauge nailer and it's the best gun I've ever had, but it is made in Japan. It has never jammed once and I've used it to shoot 2.5 inch stainless nails.
The one you are looking at is China made. Production shifted a few years ago.
boiler7904
NW IN
I've had an earlier version of Hitachi's 15 ga and 18 ga nailers for about 4 years with zero problems. I'm thinking their 23 ga pin nailer is next on my list.
For the nails, check Lowe's in your area. The store near my house carries project packs of 15 ga Hitachi nails. The difference between Hitachi and some other manufacturers is a slightly different collation angle. I'm thinking the difference is 34 degrees for Hitachi vs. 28 for others like Bostitch. You can also buy bulk packs online.
5lima30
Mountains of Western NC
A buddy of mine has a tool rental business and he has had several different brands but he has the best luck with Hitachi. That is a testament to their durability because rental tools get abused. That being said I've had good luck with PC...but I don't abuse them either.
cowboy73
southern Indiana
I never used a Hitachi, but have rebuilt several Bostitch. If you planning on using the gun alot, look into the availability of repair parts. I would base my decision on that.
Major Ramifications
River Ridge, Louisiana
Hitachi nailers are considered by many to be the best in the business. They aren't cheap, and hopefully they are still made in Japan.
The Hitachi electric power tools are good, but usually not the best available.
