Planning on 1/2" Black iron but the tank fitting is 3/8s and the reel is a 3/8. Be any issues with flow through out the system? Other than drilling and tapping the tank fitting can't think of way to make it larger other than the reducer/coupling. Realize the 1/2 lines will add to volume but if the 3/8s is going to bottle neck might as well stick with 3/8s pipe. Since that nozzle (effectively) going form 1/2 to 3/8 at the reel would raise the volume while decreasing the pressure.
