New Rule for the forum - No discussion of PVC air lines, don't ask don't tell.
Strouty
Southern Maine
I don't know how many forums I have seen where this topic drags the thread into a lot of what ifs and arguing. Could we maybe have a sticky thread created with just information about why you should and OSHA doesn't allow it. Then when ever someone makes a PVC use comment, we can post a link to the sticky. I am sick of the arguing, if someone sees the facts and uses it anyways, then so be it.
Displaced Hokie
Western NC
No one will read the sticky, and then you have sticky proliferation. Just let folks ask and we'll correct them. I don't see those discussions giving this forum too much grief.
slip knot
Texas gulf coast
What if your welding on your compressor tank using PVC rods run thru your backfed generator? Where does the insanity stop I ask?????
mrholeshot
MEMBER EMERITUS
quit fighting them. Some lessons are better learned by first time experiance. Nothing says "Thats ****'s dangerous" like getting a four foot section of PVC removed from your chest down at the ER.
Thirsty
Sparta Wi
I kinda enjoy the PVC air line discussions. Just don't click on it if you don't want to read them.
larry_g
oregon
When it comes to using PVC pipe my mind is made up, please don't try to confuse me with facts!
There are many subjects amongsk the forums that are hot buttons for someone. When I see certian subjects come up I just click out and find something else to peruse, I give you permission to do the same as I've found that banging my head against some walls hurt and does no good.
lg
no neat sig line
Frank The Plumber
Chicago.
What if you just use PVC "amongsk" friends and keep it hush hush? On the down low, on the slippity slide side. On the not for you boogaloo.
DekeT
USA
I like the PVC air pipe discussions. It is a good barometer for me to weed out the advice between posters on whom I can take seriously or not.
treasureseeker
I have read on the internet, so it has to be true that Snap On is using imported PVC gears in their dual 80's ratchets
donnie
North Carliona
What is wrong with using PVC pipe for compressed air? I have been doing it for 150 years. Should I be using PCV? ;)
Frank The Plumber
Chicago.
Then you should just use it for acetylene. :FIREdevil
No, actually, by the standard of most codes, if you are doing a test on a Drainage waste and vent system you are allowed to pressurize the system to a load of 3 PSI across a period of ten minutes and if the gauge does not drop you pass the static pressure test for the DWV system.:) You can check your code books. And it is safe.:)
