Ultimate Workbench
vintage_miata
Thought the members of this forum might enjoy the custom work/lab bench I built for my garage a couple of years ago. While it might not be everyone's ideal workbench, it works great for most projects I do. It is partially modeled after the lab benches typically used at companies that are involved in electronics work.
I used two vintage lunch room tables (circa 1940s) for the main bench top and shelf. These tabletops are constructed from thick, heavy duty plywood with a Formica top and chrome banding. Each top weighs about 80 lbs.. They came from my previous work facility when they replaced the old lunchroom furniture with new stuff. A few of the other materials such as the wheels, Formica shelves and the electrical outlet strip came from the same company when it was shut down and moved out-of-state. It's amazing what gets thrown out when a company moves.
The heavy duty wheels are cast metal with non-marking polyurethane treads and can support 900 lbs each. I incorporated a couple of basic Home Depot white cabinets for storage and built them into the structure. The upper shelf and end supports are cut from the second tabletop.
The electrical box has switches for Mains power, a Mains LED Voltmeter, an under-the-shelf florescent lamp, and switched mains outlets for a clamp-on lamp, soldering iron, or any other electric tools.
It also features:
fire extinguisher
decal collection 20 years in the making
extruded aluminum trim on all outside corners
room thermometer
bench vice
storage for a small anvil and Dremel hobby vice
detachable power cord
height adjustable lab chair
Although I started with a general design plan, there were many alterations during the course of construction, mostly based on limitations of materials. The wheels are great as it is very easy for one person to move around. Two wheels swivel and two are fixed.
For reference, the bench height is 36" and the tabletop is 30" x 72". Materials cost approximately $580.00.
Overall it was a lot of fun to design and build, and it should last a few generations!
icecactus
Very nice! I was just looking at those same wheels for a project of mine. Very expensive! Was wondering how easy it was to move.
fattogatto
How do you consider Miata's to be vintage? Miata's are the modern MGB's.
Actually, Miatas are the modern Lotus Elan. During the design phase Mazda procured several Lotus Elans and incorporated their best features, including the styling, into the Miata as the Elan was generally considered to be the best sports car of that type at the time.
oeyniman
Germany
Great job!!!
as you mentioned, the ultimate work bench - customized for you!
That does count the most - for me as well.
@GTO's remark came to my eyes 1st thing as well, but maybe you are just more 'calm' than me
Stuart in MN
Minneapolis
Nice bench, well done!
Don't forget the Miata was introduced in 1990 in the US so they've been around for more than 20 years. That's old enough to get collector plates in a lot of states. :)
djjsr
In the cornfields
Very nice! Where did you get the metal edge banding? I've been looking for some but thought that stuff was obsolete.
V
vintage_miata
Thanks for all the compliments - as usual the real trick is keeping the bench free of clutter so I can use it!
Very nice, do any of the casters lock ?
Unfortunately none of the castors have locking mechanisms. I use two small pieces of wood to keep it from moving around, but eventually I'll pick up a couple of small rubber wheel chocks.
It is very easy to move. In fact I have to move it slowly as it can carry quite a lot of momentum. I don't think I would have used the same wheels if I didn't get them for free. If I remember correctly they were about $70-$90 each.
That's pretty much my story. I bought a Miata in the summer of 1989 and it is now over 20 years old - which I still find hard to believe! I recently made the switch to "antique" plates.
The metal banding came installed on the old table tops. The first photo shows a cross section of a scrap piece, definitely from the "they don't build 'em like that anymore" category. Also, the table top manufacturers' label and a close up of one of the wheels.
Greatbear
Columbia/Fulton, MD
Great setup! Instead of chocking the wheel, you might want to try and incorporate a couple of retractable feet on either side. A foot pedal lowers and locks the foot in place, and releases it. Makes for a very stable, nonmoving bench when "parked."
