gayler
I have a problem. The company that put my system in used automotive type antifreeze. This would not be a problem, but our water is extremly hard. The system works very well when it works but the scale build up will cause coolant not to flow at times. Could I add scale defense or another simular product as I do to my hot tub and swimming pool to help out? Without it I plug the filters in both very quickly.If I need to drain the system and use RV antifreeze what can I flush the system with to clean it out? With RV antifreeze what concentration do I need? If adding water to it with RV antifreeze Should I use distilled water? Sorry for so many questions and thanks in advance for all help!
