Changing Ball Joints
Which tool do YOU use...
  • Ball Joint Press Kit
    Votes: 43 43.0%
  • Air Hammer
    Votes: 7 7.0%
  • Big Hammer
    Votes: 12 12.0%
  • All of the Above
    Votes: 33 33.0%
  • Other
    Votes: 5 5.0%
  • Total voters
    100
DrkMtnDew
Just wondering what method everyone uses for press in ball joints.
D
DrkMtnDew
I apologize. For the purpose of this Poll let stay with Press Fit.
scott37300
Wisconsin
I've always used a ball joint press or taken the whole arm off and pressed them out on a press. Can you even take out press in ball joints with a hammer? How much damage to the new one pounding it in with a hammer?
ojustracing
Albany, NY
I like using the proper tool for the Job. Ball joint press for me. But as with anything you need to make sure you have the proper adapters. My co-worker loved using an air hammer to pound them out. Made alot of noise and took a long time.
John
vssjim
McLean Va.
A ball joint can be damaged by beating on it with a hammer or not pushing on the right place on the joint, so I always take time to be sure I'm pushing on the new joint where you are suppose to.
lilredex
Toronto
Knock them out and back in with my trusty Blue Point. If you set it up properly it is a damage free operation. Have made up special tools to assist.
srmofo
SW ohio
too late, I already voted
really every make/model is different.
jimmy/blazers that have the rivets
hondas and fords that come with the control arm
dodges that screw out
chevy vans/trucks that I smack out with a BFballpein, then press in
Rear upper chrysler that can be coerced half way out with a press and finished with a air hammer...otherwise you have to remove the tank to get the upper arm off, which I refuse to do
generally speaking though if its a press fit job, I use a press. I never hammer them in,only out.
Fedwrench
Valley of the sun
Depending on application, I may replace the control arm. New ball joint, new control arm bushings, no sweating, minimal noise, what's not to like?:bounce:
gwunsch
Murrieta, Ca
Dis-assembly typically requires all of the above. As little hammer as possible, but I usually have it close at hand. The air hammer is new for me, so I've only used it once to separate the ball joint from the knuckle. The press kits in the wrong hands can mangle the new joint or arm as easily as a hammer, but the press kits are smooth when used right. Grease those threads!
melliott28
Plano, TX
I use an air hammer to separate the knuckle from the ball joint, then use a press kit to remove old and install the new.
I am a weekend warrior so I have only changed ball joints on 2 cars. First time back in the 90's on an old Mazda, I used a hammer to get the old ones out and then to knock the new ones in (no money to take it to a shop or buy a press kit). Second time about 3 years ago on a Honda and I used a press kit to get them out and to put them in. Makes the job so much easier and you don't damage the ball joints or the control arms. After using the press kit, I wouldn't consider using a hammer for that type of work; if I didn't have a press kit, I would take the control arms to a shop to press them in for me.
Stick
Alaska
That's the way I prefer to do them as well. The set I put in my truck last year was only something like $36/side more expensive than just the ball joint. At that price, it's a pretty simple choice...
blacK20
Either hammer or press out depending on situation, and always press in for install.
AZ_Catskinner
Morenci, AZ
On all the stuff I own, I use a combination of the freezer and a balljoint press for installation, and the air hammer for removal.
I did try liquid nitrogen on a set of kingpin bushings for an I-beam front end that went on my buddy's 54 GMC. It was really cool (no pun intended) - tapped them right in with a small brass hammer.
D
DrkMtnDew
i've never heard of this method for ball joints. Only things that i've frozen were valve guides.
countryroad82
Kentucky
I use a combo of BFH and the press. When it comes to installing, I also like to freeze 'em. BTW freezing u-joints and heating driveshafts slightly makes for an easy u-joint install.
