Bulldog13
Just used the 14.99 Nylon Rivet tool...some people complained about it but I found it worked like a charm.One quick squeeze and the rivet was in and the end snapped flush..best 15 bucks I've spent in a while --PASS
Are these for the plastic rivits that chrysler uses on body trim panels?
I was wondering the same thing. Do you have the HF item#
Flooring Nailer - PASS
http://www.harborfreight.com/2-in-1-flooring-air-nailer-stapler-97586.html
Just another vote for the flooring nailer. Found a magazine coupon that had it for $99.99. Even if I paid the current "sale" price of $149.99 it was cheaper than renting anything for $30/day.
I am about 2/3 done with ~750 sqft of 3/4 oak floorig and it has been great so far. Even if it craps out now I am well within the 90 day warranty so I can just get another one and finish the job.
item 67994 1/4" and 3/8" Drive x 14-3/8" Double Head Flex Ratchet Wrench. paid $30 for it full price in store
at 1st, i was hesitant to drop 30 bucks on a hf ratchet. so i passed on it. the following week i counted a few times wher ei felt owning this tool may have saved time aggravation--mostly on tight fitting accessory belt tensioner locations. so i went back and bought it.
been using it for over a month now as needed with no complaints. i dont use it as a main ratchet or anything of that nature. mostly use it as a serp belt tool. so far so good.
pass so far and recommend for light duty use-- i.e. not to use as a breaker bar or a ratchet that you exert a ton of tq on. im sure there will be a day where i will have to abuse this tool and find it's weak spot.
Pittsburgh 1/2" Extendable Ratchet.
But overall, great tool. I can easily say its the best tool I've bought from HF so far.![]()
I bought one of the 3/8" composite ratchets back in April based on the reviews given in this thread, and have been trying to break it ever since. Standing/bouncing on the handle to loosen stubborn bolts, cheater pipe over the handle .. the usual things you're not supposed to do with a ratchet.The plastic (or "composite" if you don't like calling your glock plastic) ratchets aren't heavy duty. I mean, they're pretty tough, but it's a light-weight ratchet first and foremost.
Haven't managed to break it yet, which is more than I can say for my 3/8 Craftsman flex handle .. heck, breaking the Craftsman is why I was standing/bouncing on the handle of the HF ratchet -- it was the only other thing I could find at the time.![]()
.When I was a young squirt back in the early 50s an old WW2 mechaic told me that in the long run the cheapest tool you can buy is the best quality you can find no mater what the cost. Time has proved the old fart correct over and over again!!
It has been my experience that there is a price point with just about any type of tool or even musical instrument where you get the best bang for your buck. When you go beyond that point you start experiencing diminishing returns. I have however, experienced really cheap tools and they do work as long as you don't work them too hard. Case in point, I had a set of really cheap Allen sockets that worked fine on light duty stuff but, when I really needed one to take a rusty bolt off of my old F150's mirror, it snapped like a twig. I went and bought a Craftsman and finished the job. My point is that I don't need the best tools money can buy, I just need something that will do the job and not snap like a twig.When I was a young squirt back in the early 50s an old WW2 mechaic told me that in the long run the cheapest tool you can buy is the best quality you can find no mater what the cost. Time has proved the old fart correct over and over again!!
Wow he was a real kool-aid drinker.
kind of. you do usually get what you pay for. harbor freight tools, often last for one job. a quality brand name tool will most likely last for multiple jobs. a cheap tool may get the job done, but are more likely to cause damage by rounding a bolt or breaking a knuckle when it slips or snaps. a quality tool should help you get the job done quicker (better designing, ratchets that ratchet tighter, etc). a quality tool means you shouldn't have to waste time and fuel to drive to harbor freight and replace the allen head wrenches that busted just before you were done
harbor freight has its place. quality tools have their place. this does not confront quality tools that end up being ****
yeah ... cause the truck brands have never rounded a bolt or busted a knuckle.
nice logic.![]()
The art is in deciding what quality tool you need, given how often you will use it. Then each person has to factor in their love of working with good tools vs. their own desire to spend as little as possible but get the job done. The answer is not the same for everyone, nor should it be.
i went yesterday
the 56" tool box. it has kinda cheap slides on it. in no way are these slides going to be as reliable as snap-on slides, with a lot of use.
i tried to warranty the broken 1/2f-3/8m reducer. i only brought the one piece, in the set of 3. and i was told that i HAD too bring ALL 3 pieces of the set , for the warranty
i went yesterday
