Mac Attack
- Joined
- Apr 2, 2007
- Messages
- 34
Mac,
I really like the black/grey you used. Do you happen to know what colors they were? Are they Armstrong?
What kind of prep is necessary to install the tiles over an existing epoxy painted floor. The epoxy has the flakes in it that were thrown on the wet surface during installation.
Thanks
Well, I used a low speed buffer with a white pad and the results weren't any different than just using the wax by itself.?
Any clues as to how to get that mirror finish???
John
you want to use a high speed buffer with a white pad..Well, I used a low speed buffer with a white pad and the results weren't any different than just using the wax by itself.?
John
awesome,
I might be sold on using tile.
I do have a couple of question, does the floor have to be perfectly flat? my garage is 24X26 with a 4" center floor drain, so all four sides drain to the center, but it is not a steep slope, maybe a 1/2"-1" drop in elevation. someone mentioned laying the tile out in the sun to make them a little flexible, this might help
this is a concern because, checking them out at HD, the tile seemed pretty brittle. Also, I wash my cars in the garage during the winters, would this be a problem for the tile if sealed.
everyones floor looks great.![]()
thanks Jason, your garage floor looks awsome,* I think the tile may be the way to go, I do not plan on do any heavy or real dity work in the garage for a while, i just completed the dirty part of an auto restoration, body work is going to be done somewhere else.I would rather buff the floor than touch up paint.The slope won't be a problem since it's gradual. You can wash id you seal it.
awesome,
this is a concern because, checking them out at HD, the tile seemed pretty brittle. :
You can use this to resolve your slip problems. I use this on several large box stores. They have a very low slip co-efficient.
When I tile my garage, I will use this.
http://www.armstrong.com/commflooringna/product_details.jsp?item_id=383
Its also much more expensive - Lowes.com quotes $76 per 45 sqft box ($1.70/sq ft). As compared to Armstrong Classic Black Imperial Texture Excelon which is $30 per 45 sqft box.I was thinking of using this also. But it looks like it would be a pain to clean. Any input on this?
Anyone found a cheaper online source for the Safety Zone tiles?
