Jumper Cables, recommendations plese.
twangnut
N W Florida
Suddenly my set (I've had about 18 years) are missing. Strange I saw a set that looked VERY similar to mine in the bed of my 16YO nephew the other day. Hmmm.... Well you know how jumper cables are, when you need them you need them! I believe in the one is none theory so I'm looking to pickup another set. Recommendations please, I'd like to get a good set.
Thanks
Phillip
jon1996
Never bought a set, I always make my own, I go to my local welding shop and get good welding cable 4Ga is plenty for automotive use, and then I get the clamp end and make them as long as I want, but they are more expensive this way but you get a set that will last your lifetime and many others,
Last time I was in Sams club I seen a decent looking set for what its worth
38Chevy454
Cincinnati, OH
larger gage cables the better. Think about your battery cabels on a vehicle, do you think those cheap 10 gage jumper cables can supply sufficient current? Get at least 6 gage.
TWX
Phoenix
Just check to see what they're made of and if they're thick. I once saw STEEL cable used for jumper cables at harbor freight. It didn't work very well. Looked like whoever designed those cables saw a picture and copied what they saw.
bgott
Houston, TX.
Make a set out of welding cable, about twenty foot long. They will be heavy as hell, so what! You'll be able to pull up behind a car and jump start it without having to turn around or push it back.
91FE
Harleysville, PA
I love it! 4 of the first 6 responses suggest making your own jumper cables instead of buying them... but in a thread about oil changes the other day... the common theme was that it didn't make sense to do it yourself anymore and that the dealer was the best place. :headscrat While I wouldn't go to the trouble of making my own... I sure like the way you boys think.
ibedayank
Columbia TN
because you can make a set MUCH better and longer than you can buy
Deltarat
Same as Jon. I like mine longer than normal for working around tractors and combines.
I built mine for tractors and combines as well 30 years ago and they are still going strong. I have replaced the ends, but the cables are good as new. 20' is just right.
Stick
Alaska
It's not the cheapest route, but I use a set of Warn Winch quick connectors with my jumper cables. One quick connector mounted to the front bumper of my truck, one end on a 25' set of 2ga jumper cables, and one end on a 2' jumper cable pigtail (for use with the quick connect jumper cables as standard jumper cables).
Keeps people from borrowing my jumper cables as well when I pull them out and point to the quick connect end. ;)
I'm probably in my set an extra $100 or so in quick connectors and cable, but it's well worth it IMO, just so I don't have to pop the hood.
gatewaysysop
Arizona
The ones I bought, many moons ago, were 4 gauge and probably 20'. Stout and heavy, they have never let me down. If I were doing it over, I would not want anything smaller though. Stick to 4 gauge or better if you can, you won't regret going big. :thumbup:
shampoop
SW Washington
+1
They will be WAY WAY more flexible than store bought ones, and be of heavier gauge copper so they will transfer power better. Plus you can use really nice clamps if you want. Very important if jumping GM vehicles.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
One word of advice, never jump someone and let them hook up the cables. Always hook them up yourself.
And to repeat what everyone else has stated, get the largest set you can or get them made out of welding cable, which would be the better of the two.
csp
Franktown, CO
anodyne33
Pittsburgh or there abouts
This one hit home in a really annoying and expensive way after one of the engineers my girlfriend works with gave her a boost last year. A few 40a fuses, several smaller fuses, and a few trips to the shop later and she's finally got a stable electrical system again. The bottom of the PDC still looks like we tried to make S'mores out of it though.
BrokewrenchLS1
WV
Anyone use the 4AWG cables McMaster sells? I ordered a set a couple days ago along with some other things I needed. Actually slightly cheaper for the jumper set from McMaster than just the 4AWG from the local welding shop.
Klammer
Wisconsin
Thanks
Phillip
Wow! I'm losing faith in you guys - 20 responses and not one questioning what the nephew is doing with jumper cables in his bed:eyecrazy:
Carl B
Clearwater, Florida USA
related to recommendations as to which Set To Buy.
Looks like a nice set from MC - the 4 guage 12' long are $54.80, 16' is $64.66
http://www.mcmaster.com/#battery-jumper-cables/=ecnxsw
Craftsman/DieHard 4 gauge/20 ft. $42.99 with a carry bag
http://www.sears.com/shc/s/p_10153_12605_SPM5125846001P?prdNo=5&blockNo=5&blockType=G5
Even Better - 2 gauge/20 ft $89.99
http://www.sears.com/shc/s/p_10153_12605_02807326000P?prdNo=6&blockNo=6&blockType=G6
I've had a Craftsman's Best set {4gauge/16ft.} for about 29 years now - very flexible and very durable. I'd most likely go with the $43.00 set from Sears..
FWIW,
Carl B.
kblazer87
Southeast Indiana
I bought a set of these for each of my childrens car and my wifes car.
I have this set in my truck (diesel pickup)
I bought them back before the price of copper skyrocketed, so I didn't spend this much on them, but they have been good sets and have all been used many, many times in the several years I have had them. If you can make your own from the welding cable likie mentioned above, that is a good option as well.
BrokewrenchLS1
WV
FWIW,
Carl B.
I just got the 16' from McMaster in today - look well built, good clamps, with plastic "splitters" to keep the wires from separating further where they split out. Comes with a carry bag, too, and pricing them on Jegs, they're about $80 + shipping, so the McMaster price is good.
Racecarl
McCook, NE
I got a good deal on some 2/0 welding cable so I bought 50' and cut it in half. I then went to Wal Mart and bought 4 vice grips and welded a 3/8X1 bolt on the side near the jaws. I crimped on some heavy duty ends used when making battery cables for a semi. I then bolted the cables to the vice grips. The vice grips are great because I am able to clamp onto a battery cable or starter terminal and I don't have to worry about the cable falling off.
I have close to $100 in these jumper cables and I haven't run into any piece of equipment (capable of starting) that I cannot get started, especially if I am hooked up to my semi with 4 BIG batteries. The downside is that they are REALLY heavy (40-50 lbs) but they get the job done.
