GirlnAgarage
I. Am. So. Tired. Can. Barely. Lift. My. Beeeeeer.
Let's see, today I drew the folds lines. Then drilled my corner relief holes. Ate lunch then went out and cut 8 of 10 drawer corners. That made a lot of scrap tabs. Cleaned up the edges and they were ready for folding. Folded one side of all eight. Then went back and folded the second side. Reason being I have to undo one side of the brake to slide out the sheet after it has a bend on each end. I got four done and called it a day. I busted my ****. Literally. As I was undoing a nut it got crossed threaded something fierce. As I cranked down harder on the ratchet, POP!, and my azz was on the ground. I guess throwing my leg up to apply more force to the wrench holding the bolt head left me a little off kilter. I rested a moment, wondering if any neighbors happened to see that graceful move. Got up and got the last one bent and pulled out.
Called it a day at that point. Doesn't look like I got a whole lot done but I sure spent a lot of time and effort.
The nut & bolt setup is extraordinarily inefficient. Takes too long to pull out a bent sheet and insert the next for bending. Streamlining that would be awesome.
Ok, gotta scare up some supper.
haha sorry I forgot the pics.
Thanks!
Gonna grab more grinding discs tomorrow and finish that up.
Hunting trip??
