Modern Garage in Far East
thomfr
The Netherlands
Re: Lift in Use
Here is the MaxJax in use. The difficulty with old cars is that they don't have specified lift points, but this car went up easily. At the moment, I am quite happy with the lift. It is quite a treat.
Love the Campagnolo's under your Dino!
I'm searcing already for years after the ones (which look rather simular, but re slightly different) which my father had under his 1750 GTV (the car I was transported home in after my birth) and which I would love to fit to my Guilia Super.
My dad in 1969:
Back to the topic, I love that maxjack, wonder if it is available in Europe.
Thom
michel
St-Joseph du lac Québec
I agree with Jack Olsen about the car guy heaven.
Tell me, are you going to move it around or is it installed permanently, (MaxJax)
I love this lift and it might be my next buy for the garage.
Morrisman
Angeles City, Philippines
Thank you, shopnut. The typhoon did a great deal of damage, but my family was not affected directly. Another storm, at least at strong, is due this weekend, forecast to follow the same track. I pity the folk in the provinces North of Manila, still reeling from Tuesday's typhoon, no standing homes, crops devastated, fields flooded, without electricity, and now to be hit again. I hope the storm weakens or diverts to the sea.
Thank you again.
Andy
Glad you hear you're not suffering due to the weather Andy.
I got back into Manila yesterday, amid more rain, and with another typhoon forecast. The fields are flooded on each some of the NLEX up to Angeles, but our area is dry. Floods and weather like this are just the reason our new garage and house are being built at the top of a hill, and a metre above the surrounding areas as well.
Nightshift
London, Ontario
Re: MaxJax Pump Trolley
Until Shopnut (whose garage spills over with novel ideas, many of which I've borrowed) gets a MaxJax and comes up with a more elegant device, I have simply cut off the hand-cart handles from the MaxJax's pump trolley and installed an unused chrome handle from the Proto tool cabinet. It looks better, I think. My best, Andy
Andy, I don't see the benefit really of having the pump portable ... it's not like you are likely to use that pump for some other hydraulic device. If it was me ... I would ditch the cart altogether and simply mount the pump on one of the MaxJax columns. I wouldn't want a power cord dragging across the floor each time you wanted to use it, so I would add a power cord drop from the ceiling directly over where the pump was mounted and just leave it plugged in all the time.
Shopnut ... if you don't already have your floor done up as fantastic as Andy, before you install yours, you might consider cutting a slot in the floor from the wall so you can mount the pump on the wall beside the lift and have your hydraulic line run under the floor to the MaxJax columns.
I have a Snap-on motorcycle scissor lift table for my Harley that I'm planning to sink into my garage floor so when collapsed it's flush with the floor. So when I cut the floor out for the lift table, I will also cut a slot so I can run my hydraulic hose under the floor to the power pack on the wall. To me that's the cleanest way to do it with any lift that is not portable. Jack Olsen did that too with his lift table. Food for thought. Cheers, Bill
Nightshift
London, Ontario
Michel ... it's bolted securely to the floor ... it's not moving. And imagine if it wasn't bolted and you tried lifting a precious car ...
A
abstamaria
Manila
Thom, yes, my Dino had those Campagnolos from new. I know the Alfa equivalents; they will look good on your Super. They must make aluminum (not magnesium) copies now. Have you tried Alfaholics in England?
That's a wonderful picture of your dad; the 105-series Alfas appeal to me especially.
I had to order my MaxJax from the US, so it was shipped to me. Email the US dealer (Danmar); they might be able to help.
Regards,
Andy
A
abstamaria
Manila
Michel, Bill is correct. Although the MaxJax is meant to be movable (it is quite easy to undo the mounting bolts and roll the posts around - they have wheels), I probably won't move mine.
You're right, Bill; I could install the pump permanently. The problem is that the hydraulic lines are loose too. I wish I had slots in the floor leading to each post, as you suggest.
I think Shopnut wants the option of moving his MaxJax around, so he may have to keep his pump portable.
You have a good plan for your scissors lift. Jack Olsen's installation is fantastic.
Best, Andy
A
abstamaria
Manila
Thanks, Morrisman. I am glad your area is safe. Yes, there is a depression that might develop into a typhoon within the next 24 hours. I hope you have your roof is up on the garage already.
Welcome back.
Andy
A
abstamaria
Manila
Almost done.
Thank you, Jack, James, all. I am happy you like the garage. As I mentioned before. I wasn't sure the very bare style, plain floors and walls, would appeal in GJ and was reluctant to begin this thread.
My garage pales in comparison to the very serious garages and workshops in GJ, and I am awed by them completely. However, I know (and hope) that the work I will need to do on my old cars is light repair and assembly, so I am hopeful the garage will be adequate.
Thank you for the "car-guy heaven" comment, Jack. I know I have been very lucky. I found an unwanted house that would allow the plan I had been nurturing over many years and the resources at the right time to carry out that plan. The garage is heaven for me, and I now spend a lot of time there.
With the lift installed, all the major components of my plan are in place. At this point, the dictum "less is more" will begin seriously to apply, so I should probably stop here. No more improvements or additions!
My best to all,
Andy
orange02ss
Guam/Houston
Hey Andy
I was wondering about your grass pavers again as I have been contemplating using them at my shop stateside. Yours look to be concrete grass pavers, or are they the plastic type?
By the way, I never get tired of looking at your pics, I am so glad I ran across this post as it has given me so many ideas to use on my place. Although, I don't think I could ever be as quite as neat and minimalistic right now, I hope I can come close later on after all the big projects are finished.
As for the typhoons, glad you made it out unscathed. Usually on Guam we get 1-2 a year but it has been 7-8 years since the last one. They seem to be forming further to the southeast, where before they would form to the southwest and pass right over the top of Guam. Maybe el Nina??
Robert
A
abstamaria
Manila
Robert, thanks. I used concrete grass pavers, but think the plastic ones have a lot going for them. If they had been readily available when I was building, I would have used plastic pavers probably.
We get 20 typhoons a year on the average. The difference now is that they carry very high winds or bring a lot of rain. It seems more like climate change than an annual phenomenon, unfortunately.
You are not too far from us.
Best, Andy
shopnut
Florida
Andy - Painting the lift arms and columns made a world of difference on the MaxJax. Great idea and I would expect nothing less from you. Perhaps a simple wrap-around cover on the pump trolley, painted red with silver corner trim would make it blend in nicely with your stationary workbench. That bench system has a great look, in my opinion.
Your workshop looks extremely inviting to me. Its style would encourage me to clean up every evening after each work session just so I could take one last admiring glance before turning off the lights. And I know you selected materials that will stand the test of time, even with some serious work performed in there. I'm glad to hear you have it outfitted to match your ultimate plan and that you now can begin having some serious fun it there.
Enjoy!
michel
Best, Andy
I understand the lift is made to be movable, I'll probably get one of them and was curious if you were going to unbolt it everytime or just leave it permanantly.
thanks guys for the response
rmantoo
Inspiration can be a fleeting, sometimes whimsical thing: All too often, we humans are inspired to begin something, only to find that our initial excitement was more chimeric fantasy than a true calling. Other times, what begins as a passion turns normal and mundane due to time and the realities of building, maintaining, and living our lives.
Andy, I am confident that you have provided much more than inspiration to many on this board. Your garage, your house, home, and very lifestyle are in many ways beautiful far beyond that to which we are accustomed to seeing and dealing with.
While there are many, many, fine- no- superlative garages here in this forum, I believe your garage and lifestyle will (and possibly already have) create concrete aspirations far beyond both the Philippines and garagejournal.com.
Please forgive me for taking the liberty of presuming and believing that your lifestyle is almost perfectly represented by the styling and execution of your garage and car collection. When I first read this thread, I spent well over 2 hours, going back and re-reading much of it. A week later, I did it again. When next I went into my garage, I felt crowded, almost claustrophobic, and conspicuously overdone. 5 minutes later, I pulled all of my cars and motorcycles out of my garage, sat down in the middle of the space, and began to evaluate what was needed for functionality, and what was simply there to 'fill a void' in the conspicuous consumption sense of thinking that 'more stuff is automatically better.'
What I found was that very nearly 1/2 of the objects around me were far less than necessary, far less than useful, and did nothing to add to either the style or a perceived potential use that I want in my garage- or life. Most were acquired on a whim that has no basis in either need or actual use.
I've only just begun a journey for which you bear much responsibility. While my goals are as yet unrefined, your garage, words, and life have inspired me to completely reconsider what it is I do, and how I want to do it- both within and without- of my garage. While I do not aspire to convert to a completely minimalistic lifestyle, you have inspired me to de-clutter, simplify, and to seriously evaluate each and every purchase beyond simply endorphins and money, to search within myself and decide if I truly need a thing, or whether the 12 year old, previous me simply desires it.
I am a better man because of what I have read and learned here.
Thank you.
Robert Williams,
San Angelo, Texas
Omphaloskeptic
Ultima Ratio, Wa.
Andy, I sincerely hope glossy full-page prints of your home, landscapes, and garages appear someday in a required course textbook for architects, designers (interior and exterior), and even Zen Buddhists! lol Such a wonderful execution of your vision of space, simplicity, and serenity; may your life be as sublime as your surroundings.
A
abstamaria
Manila
Thank you, Robert, Omphaloskeptic. I'm a bit embarrassed; I just wanted to show how a simple, minimalist style worked for me. But I appreciate what you wrote and am happy I have given you some ideas. Many thanks again.
My best,
Andy
hobie1dog
Cornelius,NC
I just read through all 30 pages, mezmerized, like others on here. When I cross over to " The Other Side", I'm gonna request that I get to re-incarnate again and live your life again. So much hard work, with such glorius results. I too appreciate all the extra photos of the rest of the house. Like Omphaloskeptic above, this makes me re-evaluate the material items in my small 2 car garage, and to seek a new game plan based on your minimalistic concept. Thanks for all your time and effort to share with us your part of the world.
Marty
deziac
Hey Andres, I haven't been on this forum in quite awhile, but I am watching the Car Crazy episode in the Philippines. Being of Filipino decent born in Canada, I was quite shocked that they had an episode from the PI. That being said, as I was watching it totally reminded me about you, your garage and your cars. Anyhow, as I continued to watch I thinking, Andres has got to be there, and what do you know? I see you and your Lancia....so I pull out the iPad to peep this thread to make sure it was indeed you. Awesome car, concours and crowd....its been awhile since I've visited my roots, I think it's time to reconnect....
A
abstamaria
Manila
Thanks, dezlac. Barry Meguiar was quite a treat for us in Manila. I'm sure he'd seen far better cars and shows, but he was generous in his praise and genuinely enthusiastic. He seemed to relate sincerely to the local car guys. We were quite impressed by how hard his crew worked and yet remained so friendly and accomodating.
Best,
Andres
A
abstamaria
Manila
Thank you, RusherRacing, Matt. I am glad you enjoyed the thread and the photographs. As I mentioned elsewhere, the garage is actually just an unadorned white box with identical red toolboxes, somewhat unimaginative, but I am glad that the austere style has appealed to many on this forum. That was a welcome surprise to me.
My best wishes to all for the holidays and the incoming New Year. May it bring us joy in our garages!
Andy
DARIES
Andy,
thank you for responding to my message on FerrariChat and letting me know about this website. Its very nice, saw all your pictures, congratulations again. I will start a thread soon as the construction of my garage already started. Thank you very much.
Didier.
CreteCoater
Central PA
Wow. First time I saw this thread, and I must say awesome garage! I love seeing shops from other countries. Thank you for sharing!
A
abstamaria
Manila
I am glad I introduced you to GJ, Didier. There are many really great garages here, and the threads have taught me so many things. I think you will find the forum useful in your build. I lookm forward to your thread.
Thank you, CreteCoater. I especially enjoy the threads as they allow me to look inside garages in other countries.
Best,
Andy
A
abstamaria
Manila
Garage Philosophy
First, my apology for the non-garage photo, but there is some relation to the garage.
I took this photo of our library, our most-used room, when we first moved in, some nine years ago. Since then, some furniture has crept into the room, and a large computer screen and assorted things have claimed the table top.
I would like to bring the library back to the way it was in this photo, down to that simple chair. It already then had all the things needed to make it work; since it was uncluttered, it uncluttered my mind, too, and was peaceful and calming. I want to review the rest of the house also, as it has gained a few pounds here and there, just like me. Since the new garage is already quite simple, I want to ensure that it stays that way. I have this photo as my screensaver to remind me of those goals. Those are my New Year’s resolutions then!
My best wishes to all. I hope the New Year brings you joy and happiness working on and in your garages – our havens from an often turbulent World. Thank you posting on all those threads, which have been a wonderful read for me. Happy New Year!
Andy
bww_mnm
Chicago area
Andy, i'm guessing you could fit all those books onto a single kindle and get your wall back :) I always check in to see if you posted updates/pics. Like others, I'm very inspired by your garage, home, and lifestyle.
ConCretin
Central Maine
Andy,
I noticed you hadn't posted new photos in a while. If it doesn't draw too much ire, I hope you'll continue to post photos of your garage AND house.
I've finally started my new home and have been inspired by the work you've done. Please keep em coming.
hobie1dog
Cornelius,NC
This is still the standard to which all other garages on here aspire to be when it comes to cleanliness and organization. A dream garage for me, as I'm never happy now when I look around in my garage and see too much clutter.
Awesome Andy, you da man. I'm also a book *****, so I love your Library.
magnusk750
Estonia
Somewhere in this thread you wrote something like 'having to sacrifice some convenience' for the sake of minimalist architecture and living in it' At first I bounced and thought it felt rather quirky, I mean, if you rather want to have a garage full of projects, 'might be useful' thingys and worn out tyres like most of us in fact have, then why not go with the flow. Thinking of it more I realised I do the same thing myself, but ithe other way around. I live in what is far from a minimalist home, instead it's a 50 year old restored but technically unchanged home without central heating that takes it's tolls of unconvenience.
I lived for ten years in an apartment in a modernist apartment building from 1942, though in a softer scandinavian modernist style. I can admire also the minimalist modernism, but rather the beauty of it, than that I could live in it myself, but I must admire how you carry it out.
