ddawg16
Well....I did some of that stupid **** yesterday......
Being the impatient person I am....I decided to start raising some of the beams for the 2-story addition to my house.
Instead rigging up a couple of boards with come-alongs on them, I figured I could use my new-used drywall lift.....it's good for 150 lbs....the heaviest one I want to lift is 246 lbs (3.5x11.25x20' PSL beam). Raise one end up first....then the other....that way the lift is lifting half of the weight.
First beam was easy....it only weighed 184 lbs....I was able to manhandle it up without the lift.
Second one? Well....lets just say....it almost got ugly.....
Was doing fine until I tried to roll the lift over to the side.....I had one end proped up on the block wall....was trying to lift the other end up about 9' to sit on the wall.....as I started to roll the lift, the beam slid down the side of the top bracket arm.....the only thing that saved it from slidding off and droping 8.5' to the ground was the block on the end of the arm and the fact that the beam started to roll over on it's side but the studs on the wall stopped it. It was real interesting with me up on the ladder trying to push the beam back to the center of the lift.
The above pic was taken after I got it back in place and installed some clamps to keep it from slidding.....
In retrospect.....that was some stupid **** I did.....
The lift works well....I think I need to make a bracket that will hold the beam more secure....
