Desiccant Packs
gmhill33
Greetings,
Does any use the little (unless you have the larger ones) desiccant packs in their tool boxes?
Gary
NitroPress
Aurora, CO
We call them do-not-eats around the house.
We save all the ones that come in packaging and I tend to throw them in stored tools etc. Humidity was never a problem in CA but here... well, you don't store things in cardboard boxes because they slowly turn to rubber.
Other than maybe a neatness factor or if you live in the furthest southwest, there's no reason not to save all the ones you get and toss them in the corners of tool boxes, tool cases, etc.
shopnut
Florida
They sell reusable ones in aluminum cases that can be popped in the oven and "dried out" when the indicator turns a certain color. The ones I have are about 1.5 x 3 x 1/2" in size and I found them on fee-bay a couple of years ago.
G
gmhill33
Cool I'll try to find out the cost.
Thanks,
Gary
Gary S
Bismarck, ND
I've used them around the house and garage, but I don't know if they ever helped or not. I don't have moisture problems with or without them.
Lippyp
Shropshire, UK
I use some large one at my holiday home. I have some plastic bags that have a valve so you can **** all the air out with a vaccum cleaner. We use them to store bedding over the winter when we're not there and have a couple of large dessicants packs in each one as a further precaution. Once a year I stick them in a low oven for an hour or so to dry them out. Never had anything get mildewed and the house is empty and unheated over the winter.
PCO6
Newmarket, Ontario
I throw them in my tool box drawers where I keep my air tools. As said above though, I really don't know if they are helping or not.
ClassicGMJunkie
Wheeling, WV
I usually stick them inside the service door under my wire spool in my Lincoln welder. keep humidity from eventually rusting the insulator in the gun or feed rollers.
Buckgnarly
VT
I keep them in my containers of welding rod, have not had any issues with wet rods so I guess they may be working....
James E
Raleigh, NC
I have a buddy that works for a computer tower manufacturer. They throw thousands of large packs of dessicant away and he brings me some every once in awhile. The ones he gets me are about eight inches square and about two inches thick. Lots of businesses have or get them in packaging and throw gobs of them away. Ask around and you might get some for free.
I had a car stored under a cover outside for a long time. It would mildew inside pretty badly and I'd have to clean it up every time I drove it. I put a box of dessicant packs inside and it has stayed dry and mildew free after that.
Now I keep them in my tool box, in my stored vehicles and in cabinets. I live in NC so the humidity is pretty bad here. They work great.
mpire
Florida
You can also go get some crystal cat litter at the grocery store, its the same stuff.
Any brand will do.
http://www.amazon.com/Crystal-Clear-Track-Less-Litter-Pearls/dp/B0002AQQOC
Put it in bins, or get creative and put in in cloth bags.
billwright
Here are the Aluminum Silica Gel Canisters another responder was talking about, I guess they are called "Dry-Packs":
http://www.silicagelpackets.com/dry...cks-40-gram-silica-gel-aluminum-canister.html
I use them in 5 gallon buckets with bolts, nuts, tools, etc. Works great, just pop in oven after a few months and it dried it back out to reuse again!
Greetings,
Gary
G
gmhill33
IL WI border
your tools shouldnt get rusty if youre using them and you got greasy mechanic hands;) haha had to say it.
fitz11
Fox Valley, WI
I have them in every toolbox drawer I have. I figure they are free so why not? I also got some from harbor freight made for an air dryer, it was on clearance for $0.47 a 2.2lb box have about 20lbs left so I should be good for a while lol
