The VISES of Garage Journal
bl00
Chantilly, Virginia
What's printed on the end above the numbers?
buzzdex1
Bay Area, CA
Here are some of the biggest vises I set out for a pic. L-R they are Parker 958,240#, Morgan 80,210#, Hollands 18, 280#, (2)Yost #80?(no number present on either) 261#, Columbian 508,158# ,Hollands (Lackawana RR) 255 #, Reed 208R, 291#
Back Row L-R Hollands 28, 327#, Reed 109,300#, Hollands 19,289#, Desmond Stephen 81S , 239#
I have a Reed 108, Columbian chipping vise 8" and a Parker 60 that are not here to be with the others. Would be great to have a photo of all the big ones. The Hollands is the heaviest by far but there is about 1 turn before it opens. They went cheap on the screw slack adjustment. My favorite is the Reed 208. It is the nicest vise that size that they made. The columbian is the poorest made in my opinion. It is not ver heavu on the slide and does not have the iron in it the others have. You can actually still buy parts for the morgan. When I got it the nut was missing and I got a new one for $40. Each vise has come from a different state. The Morgan is the only one found in Kansas. If anyone wants more photos or info please ask. There is 3118# og My goal is to set up a small museum of vises and blacksmith equipment. I want to have the complete line of reed vises to display as well as others. I get closer every week:) Hope you enjoy
This is exactly what I needed! For the benefit of SWMBO, I am going to print an 8x10 and post it in the shed near my very reasonable, nay, even moderate number of vises.
I am trying to think of an excuse to swing through Kansas.
Thanks,
Kevin
buzzdex1
Bay Area, CA
Re: Need Some Prentiss Help
I posted a separate thread about this, but it's been nothing but crickets so I'm going to see if it gets more traffic here:
I've been disassembling and cleaning the Prentiss Metalworker's Vise No. 20 that I bought the other day, and I've run into a question.
I've been systematically destroying the tapered locking pin on the pivot jaw trying to get it out... I've soaked it in PB blaster, soaked it in the parts washer, heated the pin cherry red with a rosebud, to no avail.
But today after taking it out of the parts washer, I noticed these pins on the left side of the vise. Have any of you Prentiss owners seen anythign like this on your vises? I'm starting to wonder if someone somewhere tried to lock this vise into a fixed position by cross-drilling the pivot and the locking pin. In any case, I'll make a new pin on the lathe, but I have to get this one out and it ain't budging.
Here are a couple of pics showing removal of the taper pin from my Morgan 340B. It was even better than I hoped because once the frog and the swivel base are removed, a punch/drift fits through the swivel attachment hole and aligns with the taper hole easing removal of the taper pin from the bottom. Had to beat it pretty hard.
5670925964885180690
5670925987363393730
5670926001592385266
Gary Indiana
near Chicago, IL
I set up a workbench this week and cleaned up dads old Dawn offset vice. It's one of the old "Made in Australia" models
Andy, that is one really impressive vise.
But... <STRIKE>the way you mounted it defeats the purpose of the offset ;) It should be mounted closer to the edge to allow the vise hold in it long objects hanging down without obstruction. That's the whole idea behind offset vices.</STRIKE>
Scrap that above remark. Vise is mounted properly - on the edge. It's the angle of the picture that makes it look like it was mounted too far.
autopts
Thats a beauty! If you got it for anything under $2.00 a lb. you got a deal. Those are hard to find, and expensive to ship. The jaw towers are massive and by the looks of it, it wasn't used much. See if you can make a stand alone for it. When those huge vises are on standard height benches they become difficult to work with. They almost sit too high (unless your tall) That 600S you want to work actually over it. It could be one reason it wasn't used that much. My 2 cents..Don't touch the outside. It still has 80% of its original paint. It looks great!
Even 11
Colorado
I'm with Nick, thats a beauty of a vise! Hope you scored it for a good deal after you dug it out of the mud!! You will never need a bigger one, thats for sure! Nice little mini clevis you got there too.
-Dane
AndysMBgarage
Mornington Peninsula Vic Australia
But... the way you mounted it defeats the purpose of the offset ;) It should be mounted closer to the edge to allow the vise hold in it long objects hanging down without obstruction. That's the whole idea behind offset vices.
The vice is actually setup on the edge of the bench, it's just the angle of the pic that makes it look like that.
Cheers Gary:beer:
Lost Road
Central California
I appreciate your advice. I was told it's owner preferred a smaller vise. I am wondering how much effort I should put in to this vise. I will keep the exterior original. The action is smooth, but it does need a lot of cleaning. Should I open it up or just give it a good cleaning. I already have a Polish vise on my bench. I will probably try to sell this locally.
autopts
Thats a tuff call, if the mininum, clean the channel bar. I don't know your financial state but me?, I would hold onto it for a while. Nobody on CL (at least around here) would pay what that vise is worth. I've sold 3 on Ebay and I shipped them. Or list it as a "buy it now" on Ebay pickup only. I've had winners 2 states away pick up vises.
:bowdown::drool:Scott,
1st----COOL.
2nd----WOW.
3rd-----WOW HOW COOL.
Love the vises, but more than that I love the wide and varied assortment of tools. Is envy a good or bad thing?
autopts
Oh, I forgot to mention, the dynamic jaw opens inward.
Yeah, its like a lazy boy of vises. You can have a wall 3" from the handle and still use it. That model is a very well make vise with the gib adjustment screws to adjust vise side play.
One note on your 600S. That front jaw is seperate from the channel bar. Its actually a 2 piece assy. I bought this 600S for a song years ago. Everyone thought it was trashed. Me and 2 other guys straightened it out on a press in 5 minutes.
tool_scrounge
Southern California
In regard to the 600S you fixed using a press, was the front jaw loose on the channel bar or was it tight but just rotated?
Thanks
Lost Road
Central California
I really appreciate your advice!
Gary Indiana
near Chicago, IL
Andy, indeed!
My apologies for the remark then, and thanks for posting more great pictures.
Aussies make some really nice tools. I've got a small Sidchrome socket set that are impossible to break :thumbup:
autopts
Thanks
It moved under about 500 lbs pressure. They are held in with a side pin so it can never come off however Wilton must make the tolerances for a tight fit. The 500S is like that also.
gatewaysysop
Arizona
Almost forgot to add my three most notable CL acquisitions to this thread:
Athol 624 1/2, 4.5" jaw (restored by the seller)
Prentiss Bulldog #54, 5" jaw
Rock Island 595, 5" jaw
Planning to restore the Prentiss and the Rock Island at some point, will update this post with newer pics afterwards. :thumbup:
otisdog
No kidding you're murdering the pin....stumped us, too.
We ended up soaking that portion of the vise in diesel for 3 weeks, and the pin plopped right out.
Regarding the holes on the side...mine were hollow. The filled on in the rear of your vice looks to be the problem. Good luck!
TreePointer
PA
I bought a hunk of paint yesterday from CL and found a Wilton vise in it! :D
I had to remove some paint to reveal what looks like "C1165." I assume that means a 5" model C1, right? Date is 2-78 and looks great on the inside. Hopefully when I remove the rest of the paint there will be no surprisses.
The 5" jaw inserts look to be in very good shape.
Rockbiter
Setting a Record today. Well, a Record 52 1/2 anyways. :) I spent some time building a new woodworking bench recently and have already set my Old Columbian woodworking vise into it. I took the time yesterday to tear this old Record vise apart to clean and lube it. It's working very smooth now so my job for this morning is to set it into the new bench top too, then the bench should be complete. It's been quite a project.
bluebolt
Benton LA
My Wilton 5" model # 745 mechanics vise picked up at an estate sale recently. This was AFTER cleaning, spent 2 hours disassembling it and cleaning the crud off. 1-79 date code on slide.
Rockbiter
The end vise is on and the bench is nearly finished. Just need to drill some bench dog holes but didn't have it in me today to do the drilling after wrestling with that vise for about two hours.
