Darren Thomas
Hi guys,
I've been reading up on the Liftmaster 3800 and really like what I see. I just have a few concerns. For those of you who have them I'm hoping you can clear a few things up.
1. When the door is closing there doesn't seem to be any possible way the liftmaster can apply a bit of pressure to seal the bottom seal nice and tight since it just allows the door to lower without applying any pressure. How would I get a decent seal? Does it release enough of the tension from the torsion springs so that the door weight seals it nicely? Can I adjust it to allow a decent amount of weight to transfer to the seal? Currently without an opener I can't get it to seal due to the tension holding it neutral.
2. It appears from the video that the dead bolt that comes with it is to be installed 4" or so above a wheel to prevent theft. I really don't want the door to open 4" before it stops. I suppose I can install it just above a wheel and be fine. Any reason that wouldn't be true?
3. Did you install yours yourself? The videos make it look pretty darn easy.
Any thoughts other than the above as well?
Darren
Darren
