What's on your walls? Neat storage ideas!
bad_idea
Pasquotank, NC
another vote for storing flammables out in the shed. i do store the paint in the hall closet inside the house tho. have to protect it from freezing. i have been keeping an eye out for a flam locker on cl.
Easterlake
Des Moines, iowa
I'm a bit picky when it comes to my shop. Since it is only 16x22 it gets messy very fast if everything does not have a place. Below are a few ideas that i came up with to keep it a bit more organized.
I have 30 of these storage bins built in under my cabinets. In them I keep assorted sizes of nails, screws, washers, bolts, etc.
I have 9 foot ceilings in my shop and used 4x8 5/8" in pine on the walls. that left me with a seam 8' up. Every place the seam was exposed I trimmed it out with a 1x3 with a 45 degree cut at the top. As you can see, I made shelves and on the back put a reverse 45 so that I can slide them on and off whenever i wish
I built these bases for my band saw, drill press and grinder. I'm thinking of opening up one end of each of the bases, or putting in small drawers for blades, bit, or whatever else.
Kent Skinner
Does anyone have a good idea as to how I can make simple chocks for these wheels? Wood? Rubber? Cheap? Easy to make? Easy to put into action?
I use spring clamps to keep my casters from moving much.
put the clamp flat on the ground, and clamp the wheel. Takes longer to talk about it than to do it, and they are cheap.
They will still move a bit, but they won't roll.
bad_idea
Pasquotank, NC
breeze,
I have it in the back of my mind to build cabinets similiar to that one of these days. What is the material on the face of the door that you use as a whiteboard? Thanks. BTW... nice work on the cabinets.
Call me the Breeze
Sebring Fl
JC... Sooner or later
bad idea... The material I believe is called Marlite? It's the smooth white stuff they sell at home depot, used in bathrooms I believe. It's 1/8 inch thick
peelman
Seymour, Indiana
Melamine or shower board is usually what I've heard it called. I had a 4x8 whiteboard in my last home office, trimmed in some oak 1x2's, cost like $30, looked like a million. When we moved my new wife's uncle took it to the tractor dealership he runs and is using it there.
With the right markers, and a supply of clorox wipes, the damned thing would last a long time, and even if it didn't, it was a still ridiculously cheap compared to a commercial board.
I just wish there was an easy/lightweight way to make one magnetic. I've thought about doing some experimenting with chicken wire or some kind of mesh on the back, but I'd think you'd need such stout magnets on the face, even with just 1/8" material on the board, that it would render it moot. I'm sure the geniuses running around here probably have a better solution for that, some kind of ferrous clear coat or spray-on stuff I'm not aware of :) There's so much wisdom on this forum its astounding at times.
nrs2420
They do make magnetic paint, but I don't know how strong of a magnetic field it is. I know the more coats you put on the better. Maybe a couple coats on the back of the board would work?
Call me the Breeze
Sebring Fl
Peelman... A sheet of tin painted white should work. You could always try it on a small piece before purchasing a large sheet. I too have heard about magnetic paint. I heard stories about racecar guys spraying their aluminum heads with it so when the inspectors would go around with their magnets looking for cheaters, it would pass the test. Could be folklore stories, but ask any old racecar driver, and they all knew one that did that, right JC?
thatcher
thanks! I cant take credit for the idea but i dont know where i saw it. it probably was somewhere on here or the hamb. its really simple. i didnt even use a hinge. i just drilled holes and passed a length of 1/4 inch rod through. the trick for me was to offset the hole front of center so that the shelves would slightly angle when they were hanging.
Mikea57
Olive Branch, MS
Zeppe,
Did you build that cabinet in the center of this picture? The reason I ask is that I have one almost exactly like it but mine has 3 drawers instead of 4. My bottom drawer has a deep face on it like yours too, but the actual drawer is only as deep as the other 2. It's kind of a pain. I'd like to scrap it and put a real cabinet in there because the way it's constructed all I can put in any of the drawers are shallow items. It works good for sandpaper and brush storage but there's a whole lot of wasted space up under there. It's very heavily constructed though...
VC455
NH
Neat idea. Can you give us a close-up of the latch mechanism (open, closed, ...)? It's kind of hard to see how it works from the pictures.
x2 i guess i'm not as smart as i look.
we got the cool fork handle extension to the bent rod, but how does it Latch.
i kept looking at the rod receiver or is it the latch rod holder...
BTW, RE: ' no need for hinges, just thru-rod'
my kind of plan, love it, great thought,. :thumbup:
omr
looks like the straight part of the latch is bolted to the shelf and the U shaped half is bolted to the ceiling then the pin goes through both to hold the shelf up ..
Jazz
Newport News, VA
I just added pegboard to my walls. At first I was like AHHHHH, but then I was like ARRRGGG... when I started reading the debate about security versus convenience. Now I'm thinking that my better tools will be keep in my cabinets while some things I use often, like screw drivers, crescent wrenches, and other "household tools" like hammers will likely be on pegboard while my sockets, ratchets and most wrenches will be in the roller boxes (I have two of the HF rollers).
One thing I really like about the pegboard is that if something is missing it's very obvious. With three boys in the house it seems I'm always finding tools all over the house that they didn't return. I'm hoping this might help that problem too.
bad_idea
Pasquotank, NC
I built these with the ideas from other members on here. Most the stuf I had laying around. the face can be used as a whiteboard which comes in handy for quick notes.
View media item 12998
View media item 12999
View media item 13000
View media item 12995
I love these cabinets and will be building some in the near future. As you stated JAZZ pegboard invites sticky fingers, and lots of dust. My plan is to build some cabinets like these above and put pegboard in them. I had pegboard along one wall for a good while and everything stayed covered in dust. When I pulled it down there was dust stacked deep behind the pegboard.
Call me the Breeze
Sebring Fl
Pegboard could easily be added to those cabinets. I've seen them made with 2x4's instead of the deck boards I used. I just used what I had lying around. I had the 3 pieces of marlyte and a few extra deck boards so I made the cabinets fit the marlyte
I still love this set up from another member here ( can't remember his name -sorry)
View media item 8429
Zeppe807
Sonoma County, Ca.
Zeppe,
There was a frame and a top when I started. I built everything needed for the drawers and face. I have all my milling tools one the left side, and my turning tools on the right side.
Thanks,
Joe
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I'd watch hanging the air tool like that. That's quite a bit of weight hanging off of the connector. They would be better off hanging with th econnector pointing up.
And if the connector woulod happen to break, the tool has a ways to fall, possibly damaging the tool itself.
Tony B
Montgomery Al
Just put up shelves on the walls for all my stuff. Track shelving with brackets and plain lumber for decking. I bought several 70" long pieces of track and then cut them into small pieces where there was only one shelf. The single shelves only need a 6 inch long piece for one bracket so instead of buying thirty or forty pieces that would be too long, I cut them up into 6 inch pieces. Simple, but effective. then peg board below it and in between the windows. Hope the photo came out ok. :thumbup:
