ForceFed70
Google it. There are different frame rates for 1080P. Do you think Netflix does 1080P at 35Mbps?
I think you got your overhead backwards. Wired runs really damn close it's rating. You'll get close to 10MB per second with a 100Mbps link. That's is about 1 CD worth of data in a minute. Which is faster then you can read from a CD directly.
Wireless you get about half what it is rated at. For G you get around 22Mbps. Anything else using the same channel shares that 22Mbps and if you toss a B client in there it is even worse. Distance from the AP comes in to play also. Along with other things that will slow it down. I don't doubt a ****** G network with wrong 1080p compression will have problems.
Full HD video 1080P is not netflix. I am talking blueray quality. That HD **** you get on netflix, Satelite, or even digital cable is not full 1080P, not even close. You might get the resolution (artifically blown up I might add) but no-where near the quality. I don't care what those marketing guys are telling you.
Playstation 3 does not support full 1080P over it's wireless connection. You must use wired. It's because there isn't enough bandwidth.
I suggest you try some googleing yourself. Like I said, the net is full of threads with guys who are unable to stream full 1080P over a solid 802.11G network.
I do think it's possible to get 2 full 1080P streams over an otherwise quiet 100Mb/s network. But never 10 and never a single stream on a 10mb/sec.
My point is that the average home user is already doing things that tax the capabilities of a 100mb/s network. So saying that "100mb/s is plenty" is not correct. It's only adequate and doesn't allow room for future technology.
