Battery Terminal Brush Contains Chemicals?
strnjss
Boston Area
So I just picked up a no-name battery terminal brush like this:
ewPKBusvcdAe_XYeDZoxjB3FxKE5HQZjdbStMfR82xTk3IKGCCIC2eWdPRtejUgK9qXJDAAtcYCHRiEUvwmpb9pxoU2F4vuNGVoh2GRznwOblXjIh177BZnnAagEPDV6F3S87VSE-FLzMuSXqH1G69YIkYWZrccu060o1NZromxq3Qhag-44JZNmuF5jU0ONEOhWvXDHjQSMoqxEYtsqyESGZcejw07YLYzI5ekxyTj-fdrbT07RXpH-iLWThM56kGUAr0QvKzCfOp5SdbCMYHblpfxlBnJk8VQzhZUh0GfT4h6-jZEzMH_EQ0YyARgrlWHlk66T9YhxW9CN76yfVF8l2w
and noticed that it, like so many other products these days says: "Warning: This product and it's packaging contain chemicals known to the state of California to cause cancer and birth defects".
How on Earth do they have to have Lead or some other chemical in this stupid little piece of metal and brush????
Do they have to put the warning on it because it's intended use is on batteries that contain lead? Or does China just pour it on to every single one of their products?
pipsters
USA
It's probably not lead, but brass. Someone else just posted about this as well but Lisle @ Sears sells a plastic bodied one for around $6.
diesel research
gulf coast, TEXAS
Cheap brass is alloyed with a minor percent lead to make machining easier. In the case of "plastic" it is also sometimes added in small amounts.
I found made in the USA toothbrush type stainless brushes for less than $1. The chinese versions are closer to $1.50 or $2. Not the best for lead top posts maybe, but great for various copper lug type terminals.
diesel research
gulf coast, TEXAS
Where? All I can get is chicom ****....
Brush Research Mfg. Co.
Brush Research is a private, family owned company located in Los Angeles, California. We've been in the business of solving difficult finishing problems with brushing technology since 1958. BRM was one of the first companies to advocate the critical need for finer surface finishes to optimize performance. Concepts such as plateau finishing were pioneered by our founder, Steve Rands, and are now commonplace goals across many industries.
The Flex-Hone® Tool is the premium standard that all surface finishing tools are compared against. No other tool can as easily, quickly, and affordably create the microstructure finish necessary for maximum performance and life of your products.
All of the tools we manufacture are still made right here at home in the U.S.A. We have over 75 employees in Los Angeles, and provide product for hundreds of distributors across the country. Our flex hone tools and industrial brushes are exported to over 50 countries around the world.
Brush Research believes in creating the best. That goes for our products and service. As Steve Rands said, "Nothing improves until someone stops and questions an accepted assumption."
It doesn't make sense to spend a LOT of extra time just for 1 or 2 $0.89 brushes, but if you are already shopping for other things or buying in large quantities, this is the people to check out.
Zrexxer
Pflugerville, TX
That's a California Prop 65 warning, which is required whenever any element or compound on their list is used in a product. The fact that a product bears a Proposition 65 warning does not mean by itself that the product is unsafe.
In this case, it's very likely the chrome plating, as Hexavalent Chromium is a listed Prop 65 chemical. Or it could be the packaging as indicated, if it's plastic containing any of the myriad of listed organic compounds.
iroc409
Maybe it's Cadmium. China has put that in a lot of our imports, like children's toys and imported tooth paste LOL.
If they're putting it in tooth paste, it could be just about anywhere.
AZ_Catskinner
Morenci, AZ
Somewhere out in the garage I've got a sleeve of golf balls that may wipe out California with all of their carcinogenic chemicals.
kythri
Lebanon, OR
Um, everything is made out of chemicals...
And in California, you've got to be careful, because the unique properties of that oh-so-majestic state cause even the most minute of a quantity of those horrible, evil chemicals to do so many awful, terrible things that they don't do anywhere else.
ptschram
Churubusco, IN
LOL-I've often thought, what is it that makes Kommiefornia so special that only they know something is carcinogenic?
strnjss
Boston Area
Thanks everyone for the responses. On the one hand, I get the ridiculousness of the California warning. But on the other hand, I like that it's forced too.
Like this terminal cleaner, I really don't care too much about. It's going to be covered in battery corrosion, and touching lead and all kinds of chemicals anyway.
But I see this sticker on things that just should not contain anything to warrant a sticker!
Like I went to buy a ratcheting tie down strap and it said it contained lead! Why? There are tie downs out there that don't need the sticker because they are made right!
Some cheap multimeter wires I bought once had the warning too, and they are meant to be handled all the time.
Heck, I even bought shampoo once that said "not for sale in California". I got suspicious so I researched the ingredients and found that one is a known Carcinogen!
I mean I know the stickers are a little overboard in some cases, but there really is no reason in many of these cases for the product to contain the chemicals that warrant the sticker.
Small risk or large risk, it's just companies being cheap and lazy.
Not everything is made out of proven carcinogenic and/or mutagenic chemicals though, which is the whole point.
stopdroplol
Most of the products that have those warning labels are not required to have them. It just opens them up to a whole mess of civil lawsuits so it's put in as a "cover your ***" type of thing.
At the end of the day though those warnings are there to protect us. If the manufacturer wanted too they could get out of it. All they would have to do is prove that the product isn't a danger under normal use, or reformulate it so it doesn't have harmful products.
kythri
Lebanon, OR
The thing is, it's not necessarily companies being cheap or lazy - it's that they really don't care what California thinks, and the fact that California's regulations are ridiculous.
Remember when saccharin was horrible and dangerous and Tab was pulled from the shelves because it was considered a carcinogen due to lab rats getting cancer from it?
That's all bogus. Most of that garbage has been debunked, and they've shown that not only is there zero evidence to suggest that it'll cause cancer in humans, but also that the amount of saccharin provided to these rats was equivalent to drinking ungodly amounts of Tab - you'd have to drink it 24/7/365 for decades or centuries to ever get that same level of saccharin in your system.
In a rare win for rationality, saccharin was delisted by the FDA and EPA from their lists of carcinogens. Wouldn't be surprised to see it still in California.
California's regulation are like that. Someone panicked about something, or someone read some study that might suggest that a particular chemical or compound might have adverse affects on Fluffy the Mouse, so California goes into red alert and lists that compound as bad - usually with no independent research or review.
The issue here isn't that companies are cutting corners or being unreasonably cheap - the issue is that California's regulations are unreasonably strict, and, quite honestly, I'd rather buy a product with California's useless warnings than spend extra money because a company felt the need to ****-up to that bastion of idiocy.
ndoran
before we are finished we will end up casing small fury animals with sharpened sticks, eating them raw and living in caves to ensure we are at no risk. mmmh! better forget that sharpened stick in case you fall on it
plinker
Northern Wi
IIRC, brass on average contains about 3% lead.
As long as you dont use it as a tooth brush, you'll be ok. :spit:
dragoocoda
Mesa, AZ
California puts the Prop 65 warning on EVERYTHING!! Funny thing, it's called the Prop 65 warning. Which means it was put on the ballot as a proposition and the citizens voted and PASSED it!!
Fedwrench
Valley of the sun
Hell, the chemicals in the battery corrosion will kill you long before the contents of a battery brush will. :lol:
Seriously, think of all of the evil chemicals a mechanic is exposed to on a daily basis, and it's enough to make you want to do something else.:bounce:
ptschram
Churubusco, IN
The raw materials like steel, brass, and copper we use in manufacturing even come with warnings and msds sheets.
Reagent grade water comes with an MSDS. Pure water, something we absolutely need to live, but is dangerous if you drink too much of it, expose yourself to the heated gas, or immerse your head in it and try to breathe.
mikeceli
Like a LOT of "Looney Toon" legislation in cali, Prop 65 is SO BROAD, lots of companies put the warning on their front doors and all products.
Drew_flux
sydney Australia
just bought a usb cable today, warning lable says" insulation may contain lead,wash hands after use and before eating"
blarf
Yup. Lead is a plasticizer. Yup. You should wash your hands after using it.
blarf
That's (hopefully) unlikely. Heavalent chrome plating is (or can be) RoHS compliant. The plating process (tri- or hexavalent) will leave you with "nonvalent" chrome. But the cost of documenting all this probably makes hexavalent plating in the EU prohibitive.
It's probably the lead.
Because lots of people prefer to stick their head in the sand? Thing with lead specifically is that your body doesn't do a good job of excreting it. So a little won't hurt, but over time it will. It's like that USB cable. Sure if you eat it, that's probably bad. Or if you make a habit of licking it. But handling it, and then handling food... it all adds up.
Why wouldn't you want to be able to make an informed decision?
Conversely, most companies take the cheap way out. There are typically alternatives... altho it is funny to walk into a liquor store and see a Prop. 65 warning. Think the fish industry has fought that label pretty well (despite the levels of mercury and other heavy metals present in most fish).
Al Bundy
Upstate NY
If you need the state to tell you to wash your hands before handling food maybe you should be poisoned thus removing you from the gene pool. Do you really need to make an "informed decision" not to be a slob?
Zrexxer
Pflugerville, TX
I must have missed what this has to do with RoHS or the EU. The question is from Boston, Massachussetts concerning a warning required by the state of California on a product that was by all odds made in China.
blarf
Point being if it (hex chrome plating) passes muster in the EU, it's probably not going to require a Prop. 65 label.
blarf
Sure. What if it's a USB device you're using in the kitchen? Or what if it were a kitchen tool with leaded plastic? Jewlery for your wife? Some of these chemicals show up in really unexpected places. If you don't care, ignore the label. What's so hard about that?
Complete list can be found here:
http://oehha.ca.gov/prop65/prop65_list/Newlist.html
Al Bundy
Upstate NY
Doesn't matter what it is. Wash your hands before you handle food. Wash your hands after you use the bathroom. You really need a label for that? It's not the governments job to be your nanny. Your mommy should have done that for you.
Every time I get a cup of coffee from McDonalds and read the "caution contents may be hot" label, I'm reminded what a nation of morons we're turning in to.
And I don't buy **** Chinese jewelry for my wife.
strnjss
Boston Area
So I know this is an ancient thread, but I recently bought a new battery terminal at Autozone which said right on the front "Lead-Free Battery Terminal".
What made this really funny is on the back of the packaging, it had the "warning this product AND PACKAGING contains lead, a chemical know to the state of california....."
The warning must get applied to products that are designed to come in contact with lead too.
y20dth
Antwerp, Belgium
Maybe it's a terminal for a lead-free battery :bounce:
