Tyvek or no?
rburke65
Canfield, Ohio
Getting closer to pulling the trigger on a 32'x56'x12 garage with OSB sheeting then steel siding. Looking to hear opinions on the pros and cons on the need of Tyvek type of house wrap under the metal siding. It will be insulated. And, what about using something similar on the roof, over the OSB roof sheeting and under the metal roofing? Thanks everyone.
bhclark
OHIO
If you're insulating, then you need the Tyvek as a second vapor barrier as well as stopping the wind/water from getting through. It's standard building practice.
They also make a new OSB that has the barrier built into the outer surface, then you just tape the joints.
toyotadriver
I would highly recommend using double bubble or single bubble foil under the metal.
red
Hudson Valley, NY
I installed tyvek on my garage, and was disappointed when on a windy day before the vinyl was finished and I felt the wind blowing thru the "vapor barrier". I promptedly caulked all the joints/cracks in the plywood (from the inside).
Ironically I fought with the modular company, that buildt my house, on a vapor barrier and they insisted it wasn't necessary because they caulked the plywood before installing the siding. They installed the vapor barrier because I sent them a copy of the local building code that required it. I would in the future use 30lb roofing (tar) paper.
dirttracker18
Slate River, ON
Once again, house wrap is not a vapor barrier. That's why you felt the wind through it. It protects your sheathing.
Al Bundy
Upstate NY
I've always used Typar. Tyvek breaks down when exposed to light. After a few years it loses a lot of it's effectiveness.
tdkkart
Eastern Iowa
A friend recently pulled all the vinyl siding off his house and re-sided it simply because it didn't have Tyvek under the siding.
I told him he was nucking-futs.
Prior to about 15 years ago you never saw Tyvek or any kind of wrap over the exterior sheeting, those houses are still standing.
It's not a bad idea, but I sure as hell wouldn't rip all my siding off to put it on.
Al Bundy
Upstate NY
I agree that your friend went a bit overboard. But keep in mind 40 years ago they didn't insulate most houses. Yes they are still standing too. But I wouldn't want to heat one.
rsa
Between Raleigh and Fayetteville, NC, USA
...keep in mind 40 years ago they didn't insulate most houses. Yes they are still standing too. But I wouldn't want to heat one.
40 years ago was only 1971. Hard to imagine a majority of houses not being insulated. Poorly insulated, yes; not insulated, no.
My modest, rural home was built in 1949 and used asphalt felt as the water resistive barrier, rock wool batts in the walls and attic.
rsa
What's that cost? About $0.50 a square foot at Lowes? Likely less expensive in bulk.
I'd much rather put the same money toward taped rigid exterior foam sheathing. 1" XPS is also about $0.50 per square foot for R-5 (the code minimum R-Value for exterior foam sheathing in the OP's climate zone—see Calculating the Minimum Thickness of Rigid Foam Sheathing. Besides the honest R-5, XPS resists inward solar driven moisture (if you use a reservoir cladding) and provides a thermal break.
See also: Radiant Barriers: A Solution in Search of a Problem.
clayton
What I find is funny is after you wrap your house with it you drive nails through it destroying the barrier you were trying to correct.
MustangRick
KC
I 100% agree. You see shows on TV where they spend hours taping every little nick and hole in it then nail the siding on with thousands of nails.
Falcon67
Merkel, TX
I don't know when my grandfather built his shop buildings, but they had been there a while when I was a kid, so thats...hell with that. OK, more than 50. They all had tar paper under the skin. The house I grew up in used it and I used it when I stripped the siding and insulated the last house. When I cut into the addition on the back of that house to insulate, I found tar paper in good condition. The addition would have been done sometime in the 70s. The wall cavities behind the paper were pretty clean, unlike the 1926 sided portion of the house that had nothing under the siding.
It's pretty dry here, and the new shop will be getting 15 lb felt under the siding, no exterior OSB. And as noted, there will be no taping or sealing. Just will overlap the rows and wrap a little around the corners (doing one wall at a time). It'll have plenty of #6 galvanized penetrations - no need to get carried away LOL. And I like the cost - $18 a roll, total needed for my 24x40 is 3 rolls.
speed bump
Butte Montana
Tyvek is designed to be a breathable vapor barrier for your walls. You put plastic on the interior and Tyvek on the exterior so that the moisture can escape otherwise given the right temperature gradient in your wall you will get ice to form inside the wall.
As far as the roof you could use felt but after I used a product called Titanium on my last roof I can't see ever using felt again. Much nicer to work with, doesn't rip, and comes out at slightly cheaper than 30lb felt.
