drawer liner
byrd
what is your prefered method of keeping your drawer liners in place?
Fedwrench
Valley of the sun
If not the peel and stick drawer liner, a little dab of 3M weatherstrip cement (aka Gorillia snaught) in the corners and middle will do ya.
kyoung
I use a brown shelf/drawer liner from Wal-Mart that is sticky/tacky enough that it will not move and holds tools really well. It's made out of cushion material with small holes in it. I believe it is around $4 a roll and will do multiple drawers.
Itzkwik
Montpelier, VA
Gotta put in a plug for the Harbor Freight $6/roll drawer liner. Stays in place in the drawers and the tools don't slide around. One of the things they haven't figured out how to screw up.
Theo
Oakville, On Canada
I use the non-slip drawer liner from Princess Auto. Sounds like the same stuff they sell @ HF. The only problem is it's tough/impossible to clean. All kinds of **** gets stuck in the holes. It's so cheap I'd probably just replace it after a while.
Merkava_4
Clovis, CA.
If you have a good drawer liner, it will keep itself in place. Those Snap-on PVC coated fabric drawer liners are just flat out awesome.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
In one box I have the rubbery stuff that has the holes in it. Except I got mine at WallyWorld. Same as Kennedy and others sell but way cheaper. But what I like most and got for my other boxes is the cheap indoor/outdoor carpet that is gray. Usually get it at Lowes for around a buck or two a running foot by six foot wide. Cut to fit the drawers and nothing slides, plus it has little grooves in it to help keep some things in place.
byrd
ive had the rubber porous liners and they did stay in place but they are a pain to clean. the solid liners i got with my mac box will not stay in place. even in the drawers with the heaviest tools they slide when the drawers are shut. i suppose i could use some 3m trim adhesive, i think i got some in the garage.
Major Ramifications
River Ridge, Louisiana
I've tried a couple of different "drawer liners" and I was not happy with either of them. I bought some dense nitrile sheet rubber, probably about 0.09" thick, which works great. It stays where I put it, dirt doesn't fall through the holes, tools don't stick to it or slide around. I was going to get it from a local rubber place but I found it much cheaper on ebay, even with shipping.
jamm
X 2 I like cheap carpet better than anything.
chavist93
North, SC
My Proto box came with some awsome liners. I wish I could find some more like them, but they are a shiny black material. The tools almost stick to it. You can slam the drawers and the tools dont move.
sharpe427
Ditto! This stuff is the best I have ever found, and way cheaper than what the tool co's. seel labeled draw liner. It also works really well as a router mat for those of you into woodworking.
Major Ramifications
Spray Rhino liner in there for a liner??? Just thought about that.
Or how about some rubberized undercoating in the spray can? Has anyone tried this? Undercoating is cheap. I sprayed the overflow pan under the evaporator in the attic with the stuff. I doesn't eat up valuable drawer height much at all. I hadn't thought about using it as a drawer liner until I read Zeroek's quote up there.
NSXSOON
Florida Space Coast
Major
Do you have a pointer to a listing for the nitrile product you used?
dxdexter
I use gravitational force. :)
It doesn't always work and the tools do cause the liners to move sometimes, but cleaning the drawers is much easier if you can remove the liners.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That's what I have in my one box. It works very well. BUT...on certain tools, it will leave a stain. I have angle plates sitting on that type of mat in my machinist box at work and it has stained where they have been sitting. And being a ground almost polished surface, you can see every mark. Nothing I can't fix though. And you can slam a drawer shut and things stay.
You might be better off getting some rubber cement from a school supply area of WallyWorld or Staples or Office Max. The rubber cement will peel right off if you change your liner, whereas the 3M gasket cement will tak a little scraping to get off. Just a suggestion.
