Here's a simple one I built that uses air. I usually set it at about 90 to 110 lbs. and work on something else for an hour or so.in for ideas. everything I keep dreaming up is way too complicated and out of budget.
i need Ronco to make one.. .set it and forget it.
Thought about using a steel drum with some sort of aerator and/or pumps to agitate the solution. But then you get into filtration and all other sorts of issues. I'm trying to K.I.S.S.
It doesn't operate under pressure. The top fits loosely however there is no danger that it will fly off - note the 3 thumb screws. The air hose causes the fluid to "swirl" and it moves pretty fast. If the barrel is half full the fluid would swirl to the top if I really cranked up the air.I'm curious about this one, it looks a lot like a pressure cooker. Pressure cookers because of the pressure force flavor and heat into what ever you are cooking.
I wonder if this works in a similar way, forces the cleaner into all the little crevices and holes of whatever your cleaning? Cleans faster?
What kind of stuff are you cleaning, what chemicals are you using?
Mm
It works well but if it "agitated" back and forth it would probably work even better.
http://www.garagejournal.com/forum/showthread.php?t=101080&showall=1
Not mine but something i plan on copying
/QUOTE]
I understand that if you keep a few inches of water in the barrel, that the whole system becomes self filtering. The junk drops out into the water and the solvent above remains clean. Anyone have experience with that idea?
/QUOTE]
Never experience it first hand but it does make sense and have heard several people on here mention it
It definately works if you use varsol. I'm not sure about other cleaning agents. I have used this method since the 70's and it works great. I gave a brief explanation of it above in post #5 above. The grit is the heaviest thing in the tank so it drops through the varsol and the water to the bottom of the tank. When I clean out the tank there is usually about an inch of crud sitting at the bottom of it.I understand that if you keep a few inches of water in the barrel, that the whole system becomes self filtering. The junk drops out into the water and the solvent above remains clean. Anyone have experience with that idea?
Here's a "heavier than water" trick you might like. I keep a few paint brushes in a small metal can in my parts washer. The can has clean engine oil in it - enough to cover the bristles of the brushes. When I paint something with enamel I wash a brush using the parts washer. When I'm finished painting I rinse out the brush using the parts washer and then put it back into the metal can. The paint that I rinse off is heavier than the water and falls to the bottom of the parts washer reservoir just like grit from parts that I wash.Right you are...........somehow missed it. Thanks for pointing that out.
Thanks for posting, I like this simple DIY ideaHere's a simple one I built that uses air. I usually set it at about 90 to 110 lbs. and work on something else for an hour or so.
Thanks. And it was inexpensive too!Thanks for posting, I like this simple DIY idea
This is what I bought as a factory replacement for my ZEP Dynaclean parts washer. States its made for solvents.Anyone found a pump that can be used with petroleum based solvents? All the ones I've seen say to use water based solvents, The petroleum solvents work much quicker and you don't have to worry about your parts rusting.
I have a HF tank and it's gone through two of the plastic pumps using petroleum solvent.
not home made but I thought it might inspire others. I picked up this pneumatic washer at my local TSC on clearance. there's a valve between the basin and the tank. Depending on which way it's turned determines whether the fluid is pushed through the brush or up into the basin for soaking. The tank holds 15 gallons and I don't see any reason why you couldn't use petrol solvents as there are no pumps to deteriorate. It's pretty easy on the air usage too. It's operation would be pretty easy to duplicate (in some fashion) with parts scavenged.
Oh, and there's an air gun that hangs on the side for blowing out the cracks and crevices.
Has anyone tried a used dishwasher using a different pump ,setting it
on a stand with a tank under it.
just a thought
Ron - The link below will explain it better than I can. Varsol is actually a trade name. I have used it as a cleaning agent for as long as I can remember. I have always got it at Canadian Tire. The current price is about $8 to $9 for about 4 litres. Like you with Varsol, I have never heard of Stoddard solvent.
Stew
http://www.exxonmobilchemical.com/C...uids-products-varsol.aspx?ln=productsservices
