Update Time!!!
Alright! So I got off work early today and the wife decided to go over to her sister's place, so I had a little alone time in the shop. I was finally able to do a little more work on the tool board, including the aluminum flashing facing and some work on the trim.
Here is the process I used, starting with a few rolls of 10" by 10' aluminum flashing rolls.
I marked them for the width of the slats on the tool boards and went to town:
Maybe
thats why it took a while
I cut about 80ft of this stuff with hand scissors
Here is what all the strips looked like laid out:
Ohh yeah, this is gonna look cool
So, next up was the tool board. Here is what it looked like to start out with:
Pretty, ain't she? Saying that backwards might be a little more accurate
After roughing up the formica (or formica-like) slats I coated them with the glue and got the strips ready:
Alright! First strip up!
Alright, ready for this?
Are you sure?
BAM!!!
Sweet! (any waviness you see in the metal was done when cutting with freakin' scissors and not when applying to the tool board
So then I started working on trim. I needed to sand it with 150 grit (already had been sanded with 100 grit) and the dang finish sander sucked. Its like the little clamp down spots aren't far enough apart and so the sandpaper just loosely attaches, which makes it tear. About 1/3 of the way through, I gave up on the sander and just went to hand sanding.
Then! I got to apply the finish. I LOVE this part because right before your eyes you get to see things drastically and visibly change. Was super fun seeing what the grain turned out like.
Wood, prior to finish:
Yes! This is what I like to see!
Check out the difference!
Finished the 1st coat:
Sitting in my garage for a while, this wood was very dry and sucked up the finish, so I'll definitely need a second coat. I'm hoping to get that on tomorrow and then maybe Friday get the trim up around the tool board. Once that is up, a cover strip (in black) will go over the seam between the wood and the tool board.
Also, several days ago I started working on the turnbuckle system. However, before that I had to individually remove each and ever panel and cut about 1/8" to 3/16" off so that the wedge fit wasn't so tight - it was actually bowing out the metal framing on the back of the door, which was causing gaps in between the panels and hinges.
So I did that and then finally got some of the turnbuckle system rigged up. I actually have 3 completed (1 more to go), but only have pictures right now with 1 up:
And here is the difference it makes, pulling up the slack in the sagging panels:
You can see the light coming through the slit between the panel that has been 'tightened' up and the rest of the sagging panels.
I don't think I'd quite get the contour to match the bottom where it meets the concrete, but I think that is more of a concrete issue than a door issue. The concrete looks more 'peaked' than the door is 'sagged'. However, this system will go a long way to helping the individual panels stay up on their own, instead of sagging and crushing the bottom-most panels.
Still lots of work to do out there and, like usual, the garage is a disaster. But, progress is being made and its been fun!
Hope you all enjoy these updates! I should have a few more between now and next week as I am also working on some paintwork with the Atlas cabinet saw. We've got good weather
