Nail size
rrbest
I'm just in the design stage for my 28X36X12 shop. I am planning to buy a good framing nailer to speed up the project. My question concerns the nail size to buy. I will be laying out my top plate and studs on the new floor and face nailing them @ 16 inch O.C. A copy of the 2003 code states that I use (2) 16D nails for face nailing or (3) 12D nails if toenailing. The largest strip nails carried by my local HD or Lowes is only 3 1/4 by .148. Am I not supposed to be using 3 1/2 by .131 or larger. I wandered by some new construction sites last weekend and all I saw were packages of 3 1/4 nails. I need to show the fasteners on my permit application. Anyone have advice?
Thanks
R
rrbest
Thanks guys, you must be correct. I searched the web and there is a plethora of answers. Non that are 100 % definitive. I will check with the mfgrs and see what they say. My local permit center says to use 16D. I didn't get to talk to an actual inspector.
Bob/Colfax
I would get one of the nailers that uses the stick of 16D nails. That way you can also use the 8D nails in them for siding and any other work that would require that size of nail. Check to make sure that the nailer will use them though, I have a Senco that will work with both sizes.
Bobg
Sundowner
West Milford, NJ
fwiw- I used the 3 1/4 x.148 nails in my garage build and no one had a problem wit it. I think the box even said 16d somewhere on the label.
if you're planning to buy a good framin nailer, the clipped head ones don't meet code anymore, so be careful buying used. I've personally had very good luch with my Bostitch coil framing nailer, I think it's a CB60 model.
6768rogues
Western NY
I have both coil and stick nailers and I prefer the stick nailer. The reason is that a coil nailer uses every nail before reloading or you waste the nails at the end of the coil. Also a coil of nails is a pain to carry in a nail bag and must be kept round. A stick nailer can be reloaded whenever you notice that it can hold another stick, without waiting for the gun to run out (which usually happens while holding something in position). Stick nails fit nicely in a nail bag or apron.
W-Cummins
Iowa
Well I have both too and I like the coil nailer better it's more compact. I have never had any problem with the nails on reuse of a coil ( when I say change from ring shank to plain ) I just pop out the old and in with the new and after I'm done the old goes right back and feeds just fine.
They also make a coil nail clip on holder for your tool belt to carry the coils. But I don't normally carry them around if I don't have to. I not sure but I think the coil model I have holds more nail too but I would have to check that as I don't have the books handy:)
William...
