Gregdoo
Replaced the 1960s main panel (old Fed. Pacific) and have MWBC in conduit on most circuits. Have breaker handle ties on the shared circuits.
I'm upgrading some circuits and adding to some. Two questions for those of you that have worked with these shared-common circuits.
1) Can I have a 20 amp and a 15 amp circuit sharing the same 12 gauge neutral? (The 15 amp circuit has a 14 gauge hot) This is how it was originally wired, but I'm not sure if it is still kosher.
2) Similarly, can I have a GFCI -protected circuit and a non-GFCI circuit sharing the same neutral (with breaker ties)?
Thanks in advance for the info!
