Why would anyone want to be responsible for checking their own tires? Some of this stuff seems to be getting stupid.AFAIK, it's not a law that regulates tire inflators, rather it's a law that states that any business that services vehicles must check tire pressures (with a high-accuracy gauge) and adjust tire pressures when necessary every time the vehicle is in for any sort of work.
From my understanding, it applies to most automotive service facilities, but there are exemptions for stuff like car washes, parts stores, body shops, glass repair, etc.
Why would anyone want to be responsible for checking their own tires? Some of this stuff seems to be getting stupid.![]()
CARB California Air Resources Board is the monkey boy of the EPA, basically charged with implementing whatever it takes to meet EPA guidelines. My wild guess, EPA wants everybody to keep tires pumped up so we use less gas.
I wonder how this is supposed to be paid for?
The tech is supposed to do it for free, because he doesn't need to earn a living...but don't get me started.
Aside from that, I have found that most people are running around with low tires, even with the govt. mandated tpms. You can't fix stupid.
i have to sign off that i did this on every car i work on, and 90% of the time its either low or at the max pressure set on the sidewall of the tire. people are to stupid to see a placard on the door jam they pass 10 times a day.
It would be nice if they were on the door jam, but the manufacturers seem to put them anywhere. Example, Volkswagen New Beetle, 2000 model, its on the inside of the gas filler door.
Also, they don't put that info in the owners manual, the manual sends you to the sticker on the car. On some cars, its in the glove box.
Charles
This list would be shorter for what Isn't regulated in california
Well, you cant legally buy windshield washer cleaner with alcohol in it. So the only washer fluid available will freeze below 32 deg. Ever try to drive in the mounains with your window covered with grime and your washer fluid freezing up?
Yes CA is that stupid (and broke)
-Jeff
It's not the owners fault. Nobody is required (or even expected) to know how to fix or maintain their own car. Most people would prefer to pay somebody to do it for them...
I'm sorry, what?
Blah blah blah, big government blah blah blah.
Honestly guys, this is a great idea. Improves mileage, safety, life of tires, and probably 20 other things. It's a win for the consumer all the way around. The smart shops would do this even if there wasn't a regulation, the cost is almost nothing, and it would improve customer satisfaction and protect them from possible lawsuits. Not to mention it's just good mechanic.
edit: also for the record CARB and the EPA really don't get along. The EPA, while good in intent is usually held in check by other government forces and lobbying interest. The CARB on the other hand is able to go further than the EPA and really embarrasses them on quite a few things.
The tech is supposed to do it for free...
If your retailer does not sell the concentrate and tells customers that it is illegal, they are misinformed.
Granted not all of CARBs rules are misguided, but enough of them without substantial research that the agencey is essentially retarded.
-Jeff
Yes.
It's called customer service... most business seem to forgotten what that is and the value the customer places on it.
I can remember pulling into a gas station, saying; 'filler 'er up' and having them pump the gas, check the battery, oil level and tires,, fill the radiator and windshield washer, clean the front and rear windows and wipe the headlamps and taillights... I think they called it 'Texaco Star Service' but all the stations did it.
I assume you have done in-depth research and fully understand all the studies and testing involved in those policies before labeling the "agencey" as retarded?
Surely you wouldn't be hypocritical enough to mock an entity for it's lack of substantial research without doing that, right?
...I guess the the point being, does the state need to be involved in all of this?
-Jeff
I pity the people who aren't even capable of checking the pressure in their tires. My 10 year old can not only check the pressure, but he can change the tire for you if you get a flat. Not sure why anyone wants to live in a world where someone else has to do everything for you. But then again I don't live in my moms basement so maybe it's different for you.
Its a catch22. I would rather not pay for the research. But when they legislate and mandate without adequate research, well, its a lose lose.
Bob, I completly agree. The downside of improperly inflated tire is less efficient milage and more tire wear. The costs of which are bore by the owner in paying for the fuel/tires and taxes associated with each. If the owner wants to remain ignorant and drive with under inflated tires, that is their prerogative.
The government didn't invent the internet. Al Gore did!..As far as government research... heh. How's that whole internet thing working out for ya?![]()
And they paid someone hourly a living wage to do that, they didn't expect a flatrate tech to stop making money and work for free, as they do now.
Boy do you have that wrong !CARB California Air Resources Board is the monkey boy of the EPA, basically charged with implementing whatever it takes to meet EPA guidelines.
The government didn't invent the internet. Al Gore did!![]()
At least give me the courtesy of a couple dots ... when you edit my quote.
......people are to stupid to see a placard on the door jam they pass 10 times a day.
Well maybe they should take some pride in their work and just do something right. They really have nothing to cry about, unlike most other technical trades, there is no required education, certification, and very little (if any) regulative oversight when working on vehicles. If it were up to me, they'd be required to do a lot more than check the tire pressure.
I was looking through the Tooltopia sale items, and found a CARB California approved tire inflator, a Branik, never heard of a regulation on tire inflators. Whats the scoop?
