Self taping screws into 3/16" steel
thejon2524
Im looking to fasten my 5/4 mahogany decking material to my truck bed this weekend. I want to use self taping screws and countersink them so they are nice and flush. However, I am affraid that if i do not pre drill them all they will just snap on me. They would be going into 1x2x3/16" c channel. Has anyone here had any experience using these screws on heavier steel is what I'm looking to find out? Any other ideas would be greatly appredciated.
feralghoul
I put super teks into 3/16-1/4 steel all day long at my work. http://garagedoorhardware.com/c6332-1000.html
Most will go right in, sometimes they get a but clogged up and you will have to turn them back, but if you dont want them to break on you after doing that just use a new screw as the tips can be prone to break off, and when they do they stick in the material so you have to start a new hole. To be safe i would pre-drill anyways, its not that much extra work to do it right.
brianvantol
I would highly recomend pre drilling them. The screws will snap and then they are a real pain to get back out. When I did my trailer I used carriage bolts which turned out nice. If you don't like the rounded tops get plow bolts from a TSC or farm store.
OccupantRJ
Eastern North Carolina
I drilled and tapped mine with a spiral pointed tap in a hand drill, then used stainless steel countersunk head bolts. Buff heads before installation for that chrome look.
Ron Lombardo
New York
I bought them at FASTENAL 5/16"-18 x 2" 6-Lobe Flat Head Floorboard Thread Cutting Screw, Type F, Black Phosphate and Oil ... to fasten 11/4 white oak on my rack body ... i had to predrill them all prior ... but it worked great and I needed 36 volt Hilti to sink them ....
Ron
vhol5
West Texas
There are screws specifically made for semi-trailer decking that would screw right in, but may take some searching to find the shorter size for 5/4 boards....
http://abctrailerparts.com/Floor-Screws.html
X2 on the screws. If you still want to use the self tappers, I have had good luck driving them in with a cordless impact driver. Very little breakage in thicker metals.
klhitman
pewee valley
all good advise above. we use self tapping screws all day long at work and when we do heavy gauge stuff some people like to pre-drill and some will run the screw a bit and throw it away and get a new one to finish the hole. if they break one they just starts a new hole. it gets covered up anyways.
but i would say pre-drill, it might take you longer but it will be better in the long run. no sense in fighting with a broken screw!
mathil
I've put in so many TEK fasteners that I think I've developed a "feel" for when they're about to twist apart. If I really don't want to dig a fastener out after it's broken I'll use one to do the drilling and part of the thread cutting and then switch to a new one to finish it off. Seems to drop my breakage percent. Pre-drilling to the size of the tip works as well, but you still get the same amount of stress when thread cutting. Frankly, once it gets to 3/16 you'll probably save time drilling with a proper drill bit than you would trying to do it with the tip of the fastener.
Charles (in GA)
50 mi south of Atlanta
The issue here is whether you are talking about thread cutting MACHINE thread screws like Ron Lombardo mentioned, which are generally not self drilling, or a self drilling, self threading "sheet metal" type screw.
You are doing a nice job, go all the way and finish the job properly. I'd drill and countersink every hole and use the self threading machine screws.
Charles
