New? HF STRUT SPRING COMPRESSOR
strizzy
Western NY
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43753
I guess I've never seen this one before, is it new? Entertaining at the least. I figured the next time I had to do some springs I would just buy the Craftsman ones with the nice heavy 'safety' pins. Last time I used the HF coil spring compressors with no problems...
RAYJAY
UNION DALE PA
i bought one just like it and have not used it yet. its a copy of otc/spx tool
just went out in the shop and tried it on some struts i have to cut for my koni's,. the tool rocks 100% easier than the 2 piece one's i have from harbor......
wait I'm sorry its not a$500.00 snap on tool so it must really ****...........lol
Jeff
picture of otc's for comparison
ImportTuner
I actuallly bought this spring compressor from HF about 5 years ago; have used it on about 6 different cars and it works like a charm ... one of the few HF items that I purchased that works ....
Moose-LandTran
The Brink of Insanity (England)
personally, i find those coil spring comressors inferior to the traditional two-piece sets. like these:
http://www.justoffbase.co.uk/core/media/media.nl?id=9762&c=317638&h=280b83b11eca43f75d63
i have the above set and find them much better, one problem with jaw-type spring compressors is that they don't compress the spring "straight" and often the jaws slip closer together, which makes one side of the spring more compressed than the other.
wythors
why.....:headscrat the otc one is made in china also.......
Because everything I've ever purchased from HF, with the exception of an aluminum dust pan, has been a huge, steaming pile of **** that either didn't work from the getgo or broke the first time I used it. I firmly believe that HF doesn't just sell Chinese-made ****, I believe it sells Chinese-made **** seconds.
strizzy
Western NY
Yeah thats what I used last time. The sears ones are here: http://www.sears.com/shc/s/p_10153_12605_00947057000P?keyword=spring+compressor
RAYJAY
UNION DALE PA
ok....... i have bought a lot of tool from them and i would say my good tool rating is about 90% from harbor,
yes i did get some **** off of them, but i really research the tool I'm buying and really look at the harbor freight quality before I buy from them maybe thats why i do not have problem with there tools
Jeff
Charles (in GA)
50 mi south of Atlanta
I have a set of the two Sears screw sticks. Very well made, but for my application, a coil over shock on a '99 plymouth breeze (and would be the same for several years of breeze, cirrus and stratus and possibly others) these almost didn't work. Lots of fighting with them, and starting and restarting and a little grinding in a couple of spots. Not very functional and I won't do it again on this car with those compressors. I'm sure they work well on some things, but not this car, due to the taper of the springs and close fit over the shocks, and the springs length, it just is not worth the effort.
Charles
porcupine73
Buffalo, NY USA
I have that hf compressor. I used it a couple times but it seemed too bulky and kind of a pain to get on the springs. I also have those sears ones linked (I think they are lisle) and those work very well and are easy to use. I usually use with an air ratchet for speedier operation.
Here's an alternative. i found this pic somewhere, this person said they didn't have a compressor so they put these zip ties on before removing the strut mount.... zoiks!
Merkava_4
Clovis, CA.
This is the kind I rented from AutoZone. It worked well for me and was easy enough to use. I can't comment about the one in this thread because I've never tried one.
stuckinohio
Dayton Ohio
Man, those zip ties scare the **** out of me. It's amazing what people will try to get around getting the proper tools. I bet renting the tool wouldn't cost much more than all those zip ties they used either.
Jason_D
The Salt City
[/QUOTE]
Obviously that person has never seen the aftermath of a flying spring!:willy_nil:eek::yikes:
Rusty67
LA, CA
My friend gave me and old school one just like the one in the original post. He calls it a bear claw spring compressor. I think he has had it since the 70s or at least since the 80s. Those 2 piece ones ****, I've never had them give me anything but hours of extra labor. This is the one I had a friend of mine buy for me, I told him it he bought it for me I'd do the struts on his BMW for free.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=45860
Now this thing works GREAT. I changed his struts and I've done a Civic with it. I can't tell you guys how EASY it is with this thing plus some impact tools to swap the bonnet. If the hydrolic ram on it ever failed I could just put a good quality one in.
PoorOwner
CA
techically some mil spec zip tie holds up to 50 lbs so it could be pretty strong with a bunch of them
PoorOwner
CA
Is that 50LB static holding force or 50LB shear strength rating ?
Not sure which one is it but it's 50lbs tensile strength which I assume it means 50lbs is stretched on the tie before it breaks. Personally I am not going to use zip ties to hold springs anytime soon though :lol_hitti
eschoendorff
Jononon
Hmm. No thanks. I'll stick to the sort Merkava_4 posted.
I freely admit I've no real evidence they're any more dangerous than the traditional style, but once you see a tool push the bones of someone's forearm out through the skin, where there was no hint of operator incompetence, or inattention, and the tool didn't visibly fail, it leaves you, shall we say, 'cautious'.
I rather wish I hadn't clicked this thread. Twenty plus years ago, and the memory of it has just made me feel nauseous :scared:
smugaim
RAYJAY is to be congratulated for his work on this topic.
I bought the HF 43753 today and couldn't figure out the "Safety Ring" with no illustration of it in-use. I Googled and found this thread, right on top.
The OTC manual at http://www.otctools.com/newcatalog/products/107300.pdf shows exactly how it is used on struts.
In the pre-Internet days, the OTC tool would have been worth the premium, just for the info!
Thanks to RAYJAY!
Peter
Rusty67
LA, CA
Its not the taking the spring off part that is hard, its puting the spring back on.... unless you are using lowering springs....
