Pneumatic Filters, Regulators and Lubricators
senlow
Wheat Ridge, Colorado
I have some pneumatic filters, regulators, lubricators, and combo devices for sale. Some are new, and some are used. All used units have been tested. I have priced the new units at about 1/3 of retail, and the used at about 20%. Prices do not include shipping. So, here they are:
Wilkerson L28-06-LK00 Lubricator, 150 max PSI, 3/4NPT, this unit was assembled in a system, but never used, $25.
Master Pneumatic CFR68-2 Filter/Regulator, 150 max PSI, 1/4NPT, New, $15. SOLD
Speedaire 3JV78 Lubricator, 250 max PSI, 1/2NPT, Used, $14. SOLD
Speedaire 2Z458A Lubricator, 150 max PSI, 1/4NPT, Used, $10. SOLD
I will also trade for the following:
Metric Thread Pitch Gauges
1-1/8" Service Wrench
NOGA Magnetic Base and Arm (or Arm only)
Small Magnetic Chuck
Proto model 1226 13/16 Combination Wrench
Proto model 1230 15/16 Combination Wrench
Proto model 1232 1, Combination Wrench
Duro-Chrome 3/8, 7/16 Combination Wrenches
VDO Tire Pressure Gauge
Knipex Pliers Wrench (any size)
Interesting ¼” drive Ratchets
Greenfield Tap Handles, #0, #00
German tools – Hazet, Stahlwille, Elora etc.
Snap-on:
Green SDD2 Screwdriver, Flat Tip
Green Pliers
XDHF810 High Performance 0˚ Offset Box End Wrench
Pry Bars
Trilobe handle Screwdrivers (especially ¼” flat tip and #4 Phillips)
Hard Handles
Spark Plug Socket, 18mm
senlow
Here are a few more:
Watts 835-02AHC Mini Filter/Regulator, unknown max pressure (my guess would be 150), 1/4NPT, Used, gauge is missing crystal, $8. SOLD
Unknown brand (If I remember correctly, it was bought from the Matco dealer) Filter, 150 max PSI, 3/8NPT, Used, $8.
Norgren F12-300-M3TA Filter, 250 max PSI, 3/8NPT, Used (Bowl & filter look new), $14. SOLD
Bridgeport Brass 750/300 Filter, 150 max PSI, 1/4NPT, Used, $10.
senlow
which one are water seperator? i may need one or two...
The following units will separate water:
LanjPerf
PM coming on these.
And this one too.
Deafautotech
Indianapolis, Indiana
how much for both to shipped to Camby, Indiana 46113?
senlow
Hey Andy,
The filters will fit in a medium flat rate box for $10.95. Parcel Post is a cheaper, but slower option at $8.23. So your total would be $28.95 or 26.23 depending on shipping options.
Deafautotech
umm.. i would like to try for Bridgeport Brass 750/300 Filter, 150 max PSI, 1/4NPT, Used, $10
i need to put that on my craftsman air compressor as i had drain out the compressor as moisture and water inside but still come out of port on compressor. so i need to see if it is work good.
let me know how much for one filter as Bridgeport Brass 750/300 Filter, 150 max PSI, 1/4NPT, Used, $10 as shipped?
what kind of payment do you accept?
senlow
That filter will fit in a medium flat rate box for $10.95. Again, Parcel Post is a cheaper, but slower option at $7.35. So your total would be $20.95 or 17.35 depending on shipping options. I accept PayPal, money order, your good check, or cash.
A filter will not do it's best job when hooked directly to the compressor. For best results, run pipe through your shop. This will allow all the water to condense, and be separated at the filter. Go to http://www.tptools.com/StaticText/airline-piping-diagram.pdf for a good, basic, description of air system installation.
