Cosmic_Monkey
- Joined
- Nov 15, 2011
- Messages
- 13
Hi All,
First time post in this great forum. I've been a lurker for a while, reading lots of posts and thought I would join the fun!
My current project is finishing off the garage/workshop that the previous owner didn't. In fact he left the floor in a terrible state! I found the big box store epoxy around the back of the garage when I moved in, so I know exactly what he tried to put down. Last weekend, I rented a diamond grinder and went to work. The epoxy came off pretty easily where it was peeling, but was bonded pretty well in some areas (I guess it proves that the cheap stuff CAN give you good results!)
The work was VERY dusty and even with the shop vac attached to the grinder there was a thick layer of dust on everything! I vacuumed as much as I could and then resorted to the hose pipe and broom to wash the stuff out. Then I noticed these strange spots on the floor (that whole rectangular area is wet)
It looks like the exact spacing of a car or truck. I know there was some 'hot tire pickup' in places in the old epoxy, so it probably from the tires, but how do I get rid of them?! I really don't want to rent the grinder again. I will try some muriatic acid and see what that does, but may have to resort to hand grinding those small areas. Any idea what I can use? It looks as though the concrete is sealed in those places (but may just be residue from tires that have been sitting there long term) and I've read that muriatic acid will not work to remove sealer...
My garage is also constructed with a course of block with stud on top. When cleaning up the edges and corners, I noticed that there is wood that was used to form the slab and it's damp and rotten. Any suggestions? I was going to scrape out the wood down 0.5-1" and back fill with concrete filler, then epoxy over this up to the block. (I was contemplating epoxy on the block but it's too much effort and would rather paint later).
Last but not least - this is the previous owners idea of a semi-professionally installed dog door (!!!) It's a basic Clopay garage door. Does anyone know where I can get a replacement panel?
I hope to get the epoxy down in a few weekends time when the prep is finished. After careful consideration, I'm planning on using a coat of preprime 167 followed by Devran 224HS and Devthane 379UVA. They are all available locally and I thought this was a good compromise between quality/cost.
Thanks for looking!
Cosmic
Thanks for looking!
Cosmic
