stickshift
I tried taking off an oil drain plug with the open end of a 17mm wrench. As you can see, the vertex on the right side of the pic rounded (really, 'gouged' seems more appropriate), but only that vertex, the others were fine.
I ended up freeing the bolt with a 17mm 6pt socket and a 3/8" drive breaker bar, which I suppose is what I should have used from the start.
Should the open ends of wrenches be avoided for freeing a fastener? I didn't want to use the box end because it was a 12pt, and my understanding is that you are much more likely to round fasteners using 12pt than 6pt.
No harm, no foul, as drain plugs are easy to find and cheap, but might as well use this experience to learn and prevent rounding a fastener in a situation where immediate replacement isn't so easy and inexpensive.
