truckman5000
- Joined
- Mar 11, 2008
- Messages
- 1,440
hi, i would like to know, if posible, to see if there is a way to insulate a steal door. The door i have is about 16'x9 overhead door. thanks
This is my first post, but I have been lurking. I would like to suggest a cheap solution, although not pretty. At the big box stores they sell 4x8 sheets of foam board used in construction. You can cut that to fit the panels of your garage door.
If you go to Lowes, they have garage door insulation kits specifically for this which you cut/fit to size. They are relieved with grooves on one side so that they "press fit" into the cavity on the back of each door section.
It is a foam material, with a smooth white rigid plastic facing on one side. I installed this at a family member's place on a plain steel door a few years ago and it came out very nice...Rob
I went to Lowe's to look at the garage door insulation mentioned here and they said they didn't have anythinglike that in the store. I then asked if they could look in their computer and the sales guy said there was no use looking as he knew they didn't have it. I did a search on the Lowe's website and didn't come up with anything although the website didn't seem very user friendly. Can anyone give me a lowes part number or direct me to the web location? I was wondering if living in the south had anything to do with them not carrying the product although I want it to help with air conditionoing. Thanks in advance!
Pirate
Did the foam help keep your garage cooler this summer? My garage is facing WSW in NC. The garage is unbearably hot during the summer. I will also have to contend with the horizontal reinforcement strapping when I insulate.
