breaker/wire size/plug ??
pete379
bought a new plasma cutter,looks like it can max draw 70 amps, on single phase 240v. I want to add a dedicated circuit,and plug. any recommendations ?
thanks, pete
W-Cummins
Iowa
If you need a 70 amp rated plug your probably looking at a pin and socket plug set $$$ if you can use a 60 amp you can get a nema 15-60p setup
William....
klhitman
pewee valley
i have a wire sizing chart on my computer at work. i will try to post it when i go in on Monday.
does the cutter already have a whip on it or do you need to make one. SO cable of that size will be pricy!!! you could get it at any welding supply house. i just bought some 8/4 wire for a job i and and it was like 3 bucks a foot.
BFBOB
You might want to get a book about the NEC. Not the NEC itself; that can be paralyzingly incomprehensible even to pros (like me, albeit a low voltage pro). Audell's has books that are more in tune with answering your questions. I'm sure there are others. Any attuned to household wiring will be guide you with this sort of project.
To second a previous poster's comments, be sure you're aware of the difference between amps of consumption and amps of output. The wiring and breakers you install to supply the welder must at least equal its consumption. Its output is irrelevant.
Greatbear
Columbia/Fulton, MD
They Hypertherm 85 draws 58 amps at 240 volts. You can use the NEMA 15-60P/R plug/receptacle with no problems.
Whatcha cutting up? Battleships? ;)
sberry
Brethren, Michigan
You can use a 6-50 P/R and most likely put it on a 8/60 circuit, a 60 because the breaker is cheap. It would run on a 50, if a guy is coming on this forum chances are he won't use this machine to its potential, its a pretty respectable unit, a couple steps up from most hobby garages, never need the maximum allowable breaker or utilize the duty cycle.
I am sure, 8/3 cord is what it calls for, if they allow for max breaker over 60 it should be 8.
P
pete379
so the 6 ga. wire i've got is heavy enough? :)
thanks, pete
Thruxton
Virginia
My advice: RTFM! I'll bet there is a breaker recommendation from the mfr in it, and that's what I would use. A quick look at the Hypertherm site and the manual for their Powermax85 shows recommended fuse sizes, for example.
