oh and mechanics gloves ALWAYS the pic doesn't do justice cuz its heeled now.. I filleted the top of my middle finger to the bone on a sheet of .024 aluminum... never again. anyway thats my life story.
Those filters have a life of about 8-10 hours once you take them out of the bag. If you only wear it for 1 hour & leave it on the shelf in the garage overnight, it's done. Always remove & (ziplock) bag them again to extend the life.![]()
Get the 3M half face mask and the welding-specific filters. It's less than twenty bucks out the door, if I remember right. You definitely want to wear it when you're working with galvanized. It fits under a normal welding helmet.
With ordinary welding, I just run the attic fan I put in my roof. But any abrasive cutting disk or blade makes stuff that I don't feel good about breathing.
i use the same one Jack listed at work. the p100s do not have a 8-10 hour life. they are a hepa filter. use them till it's hard to breath through them.
http://www.millerwelds.com/products/welding_protection/filtration/papr/#load-panel-titanium
for welding
http://solutions.3m.com/wps/portal/...ES9MG812H2000000_nid=9WCT6KC8GRbeF3RH7CD92Ngl
for grinding without helmet on, 3m 7500 series gelmask.
Also, this drives me freaking nuts that people say this all the time, they are NOT a HEPA filter. A single filter element does not a "HEPA filter" make. HEPA certification is awarded ONLY to filter systems.
Those are the base filtration requirements. Simply having a filter that meets those requirements does NOT automatically make it a HEPA filter. The filtration efficacy must be certified AND the housing plus filter must be tested to ensure that it's not possible for any air to bypass the filter element. You can have the best filter element in the world and it won't keep you alive if the air can go around the filter because of the crappy fit between the filter and the housing.NO! Read:
http://en.wikipedia.org/wiki/HEPA
"To qualify as HEPA by government standards, an air filter must remove 99.97% of all particles greater than 0.3 micrometer from the air that passes through"
Exactly, those are the certification requirements for NIOSH *95 and *100 filters. Being a NIOSH-certified filter does NOT automatically make it a HEPA-certified filter.N100 and P100 filters (the pink 3m disc filters are P100) remove 99.97% of all particles greater than 0.3 micrometer from the air that passes through.
That's how N100 and P100 are defined.
Nope, got this wrong as well.The difference, is that N series filters are not resistant to solvent particulates in the air, whereas P series are.
Yeah, they're wrong or at least their command of the English language *****.This even states:
"The P100 filter is the same as a HEPA filter and is likewise coloured magenta."
I've seen a body shop guy cut a small hole in his disposable mask that he could poke a cigarette through...
